2 12s in back of t/a
i have 2 12" JLW3v3's i would like to put in my trunk but i dont know if theres room with out using t-top holders(i use them quite often). i figured i can place the amp on the back wall of the t-top holder since there clearance but where can i put the subs while keepin my t-top holders
Here's my old setup with two 12"s in a Q-Logic box. Two W6s and a bd1500 and a cap. Box is for sale. I don't take my T-tops out very often and when I did I'd just put them in the backseat.
put them on the shelf. i have 2 15's up there without a problem. also have had a single 12 there, 2 12s and ive recently moved the 15s into the backseat, however 2 12s fit great on the shelf
I guess I'm alone on this but I like the look of the Q-Logic box over the Subthump and to me the t top storage is overrated. Is there anything in the subthump box to keep the t-tops from slapping against each other or a divider or something? When I rarely removed my t-tops I would put them in towels in the backseat or leave them at home, that seemed better than stuffing them in a slot under under a speaker box though that wasn't an option the q-logic but I considered both before buying the q-logic.
You know if you rear end some one your dead. Right....
Re'
Originally Posted by RE AND CHERYL
Oh My God! That is about as Redneck getto as you can get. Can you even see out the back window???
Re'
Re'
and i dont drive like a jackstaff so rear-ending someone is unlikely. and if you think that 120 lbs box is gonna fly off the shelf, your wrong.GTFO
Re'
Re'
