HELP!!! Urgent!!! Security system-stock-can't start car!!!
I was pulling out all of the interior on my car and pulling stero wires. I moved the security bock by the stock amp and now car is not turning over at all.
HELP!!! What do I need to do to clear security system or bypass it?
Ungrounded Moderator
The only part of the factory alarm system that is near the amp is the shock sensor. The car doesn't care about the shock sensor as far as starting - lots of people disconnect them when they start causing false alarms. In fact, the factory alarm system isn't even connected to the starter - the separate VATS system handles that.
Unless the security light is lit on the dash, the starting problem is probably not related to any security system. I suspect you have a blown fuse or a loose connection somewhere.
