pioneer avh p5700dvd
ok just got this from my room mate it was in his gto, I wired it up and installed it into my car (via Wiring Harness) everything works exept sound, it says its on mute and wont turn off. at all. i need help!
i had that happen on a unit i installed once, i just pulled the mute wire out of the harness and it fixed it, i dont remeber if that unit has a mute wire, but if it does try that to see.
yeah i called a friend of mine and he came over I wasn't entirely sure that this wire needed to go to that spot and i snipped it turned it on and now works just fine lol. but now I cant seem to get it to play the video of dvds even when i'm parked i even tried sending 12 volts to the wire at all times and it still wont. so now i'm stumped again!
Ungrounded Moderator
The parking brake switch is a grounding switch. Connecting the wire to the switch provides ground (not 12V) when the parking brake is engaged.
If you continue to just randomly feed 12V power to wires for testing then you're going to end up with a fried head unit.
