Replacing Speakers
Replacing Speakers
Guys, I'm replacing the blown front door speakers in my 02 TA. Crutchfield has three good replacements offered in my price range. Alpine SPR17C which is rated at 2-100 watts RMS power range, Boston Acoustics SX65 rated at 2-50 watts RMS power range, and JL Audio TR650CXi rated at 2-50 watts RMS power range. I believe that they are all rated at 4 ohms, and the stock speakers are 2 ohms. My question is will the 2-50 watt RMS range be able to handle the power range of the Monsoon amp and will the 4 ohm speakers lose much power. Also, do you have to remove the door panel for speaker replacment?
You are perfectly fine using a higher impedance speaker than original ratings. You most likely will not hear a difference in power loss - search for more info on this, as it has been discussed several times.
