One head light wont go up or down
98 pontiac t/a ws6
i hit a pot hole and one headlight didnt go down and i put it down manualy and it wont go back up with the switch. The fuse looks fine. is it the motor or just like the connection?
Ungrounded Moderator
First, never trust a fuse that looks fine. Fuses often look fine when they're actually blown. Always use a tester or replace the fuse with a known good one.
Second, did you check one of the two headlight door mini-fuses (left or right as necessary) in electrical junction block #1 under the hood on the left fenderwell?
