Rear view camera
Old 01-29-2008, 05:52 PM
Phantom_WS6's Avatar
Exclamation Rear view camera
Anyone put a rearview camera on a camaro? Where did you put it? And how is the night visibility? I couldn't find anything on this. I have a 5% tinted back window and I need a rearview camera, already have a dvd radio in the car with an input for a camera.
Old 01-29-2008, 05:57 PM
Zeke34's Avatar
I would like to know the very same thing except for a T/A... Subscribing...
Old 01-29-2008, 06:07 PM
KEE AUDIO's Avatar
I carry several of them. They range from $49.00 to $180.00. The T-View back up camera is a black license plate (comes mounted) with night vision, 170 degrees of viewing angle and is of course water proof. It is $149.00.
Old 01-29-2008, 06:39 PM
That sounds great. Do you have any pics or anything? How is it installed on the plate?
Old 01-29-2008, 06:46 PM
richieg's Avatar
does lp camera send a reversed (left to right mirroring) signal, or have a switchable signal? Or better yet, do you have any kind of inline device that will achieve the same effect? And like stated before, any pics?
Old 01-29-2008, 07:43 PM
MasterEvilAce's Avatar
I saw a guy at work get one put on his truck.. license-plate mounted as well.. the view screen inside had a couple of buttons to mess with brightness, and screen orientation / flipping. Probably the same kit, really
Old 01-29-2008, 08:13 PM
Aren't the license plate mounted ones easy to steal? Someone can steal it easily from you. Is there any way to mount them in the keyhole for the hatch?
Old 01-29-2008, 09:10 PM
That's not a bad idea. I think the camera was a little bit too big for that hole, though. Unless you enlarged it. If it was the size of the doorlocks on the side, it would probably fit.
Old 01-30-2008, 10:09 AM
blackbird007's Avatar
I've seen one in the key hole of a TA. It was sweet. I'll see if I can dig up some pics.
Old 01-30-2008, 12:13 PM
KEE AUDIO's Avatar
The less expensive one is just the camera without the license plate so that may be the way to go with the keyhole application. The license plate ones are a premounted unit but you can always buy the caps the go over the license plate screws and use all 4. This can deter would be theives as it takes too much time to get it all off. I will get some pics up tommorrow.
Old 01-30-2008, 11:27 PM
Yea post some pics if you can. I'm really interested.
Old 01-31-2008, 07:04 AM
94BlackSSClone's Avatar
Old 01-31-2008, 06:55 PM
renxwar's Avatar
One more request for pics.
Old 02-01-2008, 04:32 PM
KEE AUDIO's Avatar
Here you go guys! These are the different models I currently have.
This is the BOYO VL 300/200 and is also available for the same price in metallic silver,$162.95
Features: Built in license plate in zinc metal black or silver frame, waterproof, 130 degrees of viewing angle, compatible with a variety of monitors, CCD technology enables 5 X the brightness at dark illumination, chip resistant coating
NESA Vision LPC2, $134.99
Features: Water/fog/dust proof, chip resistant coating, 150 degrees of viewing angle, backlight compensation circuit, compatible with any monitor, electronic iris, extremely small camera size
T-View LS300NV: Available in black or silver, nightvision, 170 degrees of viewing angle, waterproof. $139.00 No pic available right now. I'll get one later. Same style as above.
BOYO VTL100: Same as above with 130 degrees of viewing angle but the plate is thick chrome plastic $132.00
BOYO VTK100: Keyhole type mounting, same as above with CCD Technology, high resolution. $129.00
I have more but this will do for now. I'll get some fo the others up later!
Quick Reply: Rear view camera
