Double DIN Installation - LS1TECH
Stereo & Electronics Audio Components | Radars | Alarms
Thread Tools Search this Thread
Old 03-25-2008, 06:01 PM   #1
Ungrounded Director
WhiteBird00's Avatar
Default Double DIN Installation
For those of you who have installed a double DIN head unit, what did you use for mounting brackets?
I'm about to install a Pioneer AVIC-D3 with all the extras (bluetooth, sirius, etc. ...and yes, I have the customized trim bezel) but I realized I can't just swap the factory side brackets onto the new HU - there's no mounting holes that match up. The Metra kit doesn't help for the same reason. Did you have to make custom brackets?
Any other installation tips would be greatly appreciated.
WhiteBird00 is offline   Reply With Quote
Old 03-25-2008, 07:07 PM   #2
I know on the vettes a few guys have used metal brackets from ace hardware, i forgot what they were called
http://inlinethumb27.webshots.com/16...600x600Q85.jpg
pentavolvo is offline   Reply With Quote
Old 03-25-2008, 07:34 PM   #3
phantomzer0's Avatar
I bought a metra double din kit off of ebay for like 10 bucks. It comes with clips for both sides of the unit. Once you attach them and set the unit into the car, the brackets line up with the holes for the actual radio bezel. When you put the bezel on the poles will go into the factory holes and hold the clips in place. I'll try to get a shot tonight of it for you.
The clips don't actually secure to the car until you attach the radio bezel. It's not the most "theft deterrent" but it works quite well.
Nice choice on the avic btw, its a really good deal, especially if you use an ipod or xm!!
phantomzer0 is offline   Reply With Quote
Old 03-25-2008, 07:41 PM   #4
Here's the link to the ebay auction with the kit I bought.
http://cgi.ebay.com/Chevy-Pontiac-Do...QQcmdZViewItem
Old 03-25-2008, 07:49 PM   #5
Copy & Paste Moderator
VIP1's Avatar
Look in this thread for many more links to threads on Double-Din:
http://www.ls1tech.com/forums/showthread.php?t=740828
VIP1 is offline   Reply With Quote
Old 03-25-2008, 07:54 PM   #6
I know this is probably a stupid question, but where did you get the customized trim bezzle, or how did you make the trim bezzle. I am assuming it is for a trans am, if you would let me know I would greatly appreciate it, as to say I want to get the same set up as you are installing
Thanks JP
Homez114 is offline   Reply With Quote
Old 03-25-2008, 07:58 PM   #7
phantomzer0
so did you use that dbl din kit and it just like bolted up in the car
Old 03-25-2008, 08:10 PM   #8
Yeah. Though this is in a Camaro. I'm not sure how this would mount up in a Firebird / Trans Am. You might need to modify or try to fit it differently, but it worked out great for me.
Here are my pictures.
You can see from the photos that the holes are not the mounting kit holes, they are the ones for the bezel to attach to the car.
Old 03-25-2008, 09:30 PM   #9
Ungrounded Director
Thanks everyone! I was thinking I might have to make brackets out of some sheet metal but I like the idea of using the double DIN Metra kit - I think I'll give that a try. It looks like it will fit pretty much the same way in the T/A as in a Camaro.
Phantomzer0, did you have to cut out the factory tray under the radio opening? It seems like it will be a really tight fit otherwise.
The bezel is a prototype from a member who is not yet a sponsor here (but thinking about it). He sells them for Camaros but this is his first Firebird bezel.
I got the new SCV-DOC1 that allows you to control a plug-and-play Sirius receiver from the Pioneer head unit. That means I can use my satellite radio just like it was built in to the head unit but I still have the flexibility to take the tuner out for use on my bike (saves paying for an extra subscription).
Old 03-25-2008, 09:38 PM   #10
Quote:
No sir! My unit sits perfectly flush right on top of it. I can take the unit out tomorrow and do some test fitting in my Firebird if you want.
Old 03-25-2008, 09:47 PM   #11
Ungrounded Director
Thanks, I really appreciate the offer but I don't want to put you to any trouble. I test fit it today (before I found the bracket problem) and noticed that I would either have to trim a bit across the top or remove the bottom tray. The opening seems to be about 1/8" too small for the body of the unit. I'd feel much better having it sit on the tray for support even if I have to do a small amount of trimming of the opening at the top.
Old 03-29-2008, 04:29 PM   #12
Make sure you have enough room in the back for the fan to blow out the unit's heat. If it cannot properly circulate the air then it will go into a protection mode. If it goes into protect mode, it will mostly be un-useable. Just check, and double check that you have enough clearance in the back.
Old 03-29-2008, 09:21 PM   #13
Ungrounded Director
How much clearance would it need? I installed it today (pictures to follow) and I figure there's about an inch behind it.
Old 03-29-2008, 09:28 PM   #14
should be adequate
Old 03-30-2008, 12:39 PM   #15
Ungrounded Director
Here's what it looks like installed:
The D3 allows you to load up custom backgrounds from disc so I created one with the screaming chicken logo.
Old 03-30-2008, 01:13 PM   #16
whitebird so what did you do for mounting it
Old 03-30-2008, 01:29 PM   #17
That looks really good, we trans am owners need those bezzels mass produced. That is a super clean look, and you did a great job. PM if you know how I could get one of those bezels, would really appreciate it, and nice set up
JP
Old 03-30-2008, 03:06 PM   #18
reaper95's Avatar
Very nice, when my money looks a little better that is my next project.
reaper95 is offline   Reply With Quote
Old 03-30-2008, 04:20 PM   #19
Ungrounded Director
Quote:
I used the double DIN mounting kit that phantomzer0 suggested. It's such a tight fit in the opening that you really don't need much support. The brackets from the mounting kit just help keep it in position but the support mostly comes from the factory tray.
Old 03-30-2008, 07:16 PM   #20
so if you pull the bezel off it will just like slide out,
Related Topics
Thread Thread Starter Forum Replies Last Post
Kenwood Double Din install Completed cajunss Stereo & Electronics 9 04-10-2013 07:29 AM
Where do you guys get Double Din bezels? Dave Simkus Stereo & Electronics 15 03-24-2013 08:43 PM
Firebird gauge mounting, double Din to 2 single Din units w/ gauge mount cyteone Appearance & Detailing 6 02-19-2012 02:20 PM
Double Din in trans am ???? Chaos07 Stereo & Electronics 10 03-30-2010 11:21 AM
I'm thinking about doing a Double Din Stereo install in the 2001 camaro I'm getting soundengineer Stereo & Electronics 3 01-06-2010 05:11 PM
Tags
2000, 2001, brackets, camaro, custom, din, double, fit, install, installation, installment, kit, mounting, pictures, radio, stereo, trans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
