Wiring Gauges Into Light Dimming Switch?
Hey well I am wiring my gauges right now and I want to wiring the lighting part of the gauges to the interior light dimming switch and when I pulled it off there where four wires, Green, Black, Grey and Brown....
Any one have a wiring diagram or even know which wire is which?
Thanks in advance....
Ungrounded Moderator
The best place to get accessory power is the fuse box. There are three extra ports in the dash fuse panel that were designed by GM for use installing electrical accessories. One is BATT (constant battery power), one is IGN (ignition controlled power), and the third is ACCY (power when the ignition is on and during RAP operation after the ignition is off before opening a door - like the radio). They are single spade (flat) ports like half of a fuse socket. You can just put a spade connector on the end of your power wire and plug it into your selected port. Each is a 15-amp circuit so you should provide a smaller inline fuse if your gauges don't require that much power.
