Standard Replacement Speaker System
I was just wondering if anyone has purchased this from KEE audio ($277.00), my speakers are getting old and worn and need to be replaced. Just wondering how this setup sounds and if its a direct bolt up replacement. Thanks
I'm offering 2 packages one is a standard package ($277.00) one is a premium package ($379.00) and I'm working on a super premium package as well. It replaces all the speakers in your car for Camaro and Firebird. I will be swapping out the sail panels for the 6.5" DVC subs when I get enough of them in. Currently these are available in any of these packages while supplies last.
Here's a link to them so you can see what they are:
http://www.keeaudio.com/id79.html
I can also add stealth enclosure, amp, and sub into the mix and even aftermarket amplification for a whole system overhaul. I've done several of these in the past and they do quite well. The speaker packages are just a speaker upgrade if your looking to get rid of your stock junk before it starts rattling.
I can add, mix and match any component to match your tastes. And when ordered as a package it saves you money.
