Street Racing & Kill Stories Basic Technical Questions & Advice
Mach 1 vs Trans Am
Old 04-30-2010, 11:15 PM
01' Sevan Series T/A's Avatar
Default Mach 1 vs Trans Am
A little fun in Mexico Thursday night:
1st run:
http://www.youtube.com/watch?v=OVHpAqDnwfw
2nd run:
http://www.youtube.com/watch?v=aSeFD0YEiOE
01' Sevan Series T/A is offline
Old 04-30-2010, 11:36 PM
00silverGTP's Avatar
mods to each? mach rolled out...
00silverGTP is offline
Old 04-30-2010, 11:42 PM
Tech Apprentice
Stopsign32v's Avatar
Wow that Mach 1 must have nitrous AND boost to outrun a LS1 like that! I mean stock for stock and mod for mod the LS1 has the edge at higher speeds right?
Stopsign32v is offline
Old 05-01-2010, 12:01 AM
04Mongoose's Avatar
I own the Mach 1, the Trans Am sprayed me on the 2nd run. I am not running any nitrous on my car. I still have a stock longblock with the only aftermarket stuff on my car being full slp exhaust and jlt cold air intake.
04Mongoose is offline
Old 05-01-2010, 12:06 AM
Tech Apprentice
*sits back*
Old 05-01-2010, 12:16 AM
BigBirdLS1's Avatar
You said that the T/A sprayed on the 2nd run I didn't really see any difference between both runs. I did see that you were ahead on both of them. Do you know the mods on the T/A you said nitrous but is it an A4/M6 (A4 stalled). I'm definitely not throwing the BS on you because the videos tell the story. Howevfer I'm not totally sure that you have the mods correct on either your car or the T/A. Just my .02 Either way Nice Kill.
BigBirdLS1 is offline
Old 05-01-2010, 12:24 AM
04Mongoose's Avatar
The t/a driver told my friend he was going to spray me on the 2nd run if he needed to. He said it was heads cam intake stalled turbo 350 (obviously too big of a stall) and nitrous. Also you can tell his car hits harder from the start in the 2nd video. A follower told me that it puffed black smoke on the 2nd run and broke the tires loose and it didnt on the first so he probably sprayed me but given his stall is too big it did him no good
Since you can't hear my car at all in the video here is an exhaust clip. Its a stock long block car with bolt ons.
http://www.youtube.com/watch?v=jVMozcxsdZE
Old 05-01-2010, 12:25 AM
odarabla's Avatar
There's no doubt the Mach rolled out but I don't believe this guy is the owner of the Mach 1. I believe that the OP and this guy are trollers planned on coming on here to start ****! Both the OP and this guy are brand new to the LS1tech world and zero post count! What"s done to the Mach? If that T/A would have sprayed the Mach would have seen tail lights unless he was heavily modded!
odarabla is offline
Old 05-01-2010, 12:26 AM
04Mongoose's Avatar
damn i wish I still had 45k miles....got the car in sept 09 at 40,800 and now I am at almost 53k I drive too much!
Old 05-01-2010, 12:28 AM
04Mongoose's Avatar
Originally Posted by odarabla
There's no doubt the Mach rolled out but I don't believe this guy is the owner of the Mach 1. I believe that the OP and this guy are trollers and planed on coming on here to start ****! Both the OP and this guy are brand new to the LS1tech world! What"s done to the Mach? If that T/A would have sprayed the Mach would have seen tail lights unless he was heavily modded!
I got on here today because of some bull **** that happened at the car meet last night and the person who started it is on this board. I can assure you that I do own the car in question
Old 05-01-2010, 12:32 AM
odarabla's Avatar
So you are saying you beat a H/C/I sprayed T/A with a bolt on Mach 1?
odarabla is offline
Old 05-01-2010, 12:35 AM
odarabla's Avatar
If that is the case, I tell you what. Where you live? I got a H/C/I stock bottom end Full weight Camaro you can run. I got $5000.00 on the race and we will get it on video. Best 2 out of 3. I'll even give you the hit!!
odarabla is offline
Old 05-01-2010, 12:39 AM
04Mongoose's Avatar
Is this proof enough?
http://www.youtube.com/watch?v=d8Acr_uTI9c
Old 05-01-2010, 12:40 AM
04Mongoose's Avatar
he is blowing through the converter! him spraying me the 2nd run did nothing for him at all!
Old 05-01-2010, 12:42 AM
odarabla's Avatar
That's some funny ****!! Nice car man but I don't believe that the T/A was a H/C/I and sprayed! I know that not all cars are the same but that should at least be a mid 10 second T/A with the said mods unless it isn't setup right. A bolton Mach would have it's hands full with a bolton LS1! I went 12.60@107 with a bolton Z28 Camaro
odarabla is offline
Old 05-01-2010, 12:43 AM
BigBirdLS1's Avatar
You still didn't answer my questions on the mods of the T/A. The T/A hit "harder" on the 2nd run as you put it because the camera car was closer to the cars at the start of the race. I will renig on me not throwing the BS flag because IF you are being truthful on the T/A having nitrous then you have to be lieing about your only mods being full exhaust and CAI. I'm officially calling Shenanigans.
Ok I see where you said that the T/A is spraying through the converter. Though I am still not seeing how you out ran a H/C car I guess its possible not likely with a good setup/running car. Nope that **** aint happening I'd tell the T/A guy to get his money back on the H/C cause his crap is SLOOOWWW.
Old 05-01-2010, 12:45 AM
odarabla's Avatar
I second that!!
odarabla is offline
Old 05-01-2010, 12:48 AM
04Mongoose's Avatar
call it what you want... listen to my video its nothing special just a little mach 1
Old 05-01-2010, 12:50 AM
Tech Apprentice
Old 05-01-2010, 01:02 AM
BigBirdLS1's Avatar
That crap is HILARIOUS!!! You always make me laugh.
(sarcasm) I am TOTALLY a GM nutswinger
Quick Reply: Mach 1 vs Trans Am
