Street Racing & Kill Stories Basic Technical Questions & Advice
Duramax Puttin the Hurt On Everybody
Old 11-21-2011, 03:34 PM
Bitemark46's Avatar
I think what tsiawd was trying to get at is that he probably moved his peak torque higher up in the band thus making more hp. If truck A made peak tq at 2500 rpms and truck B made it at 3500 (both the same output just at a different rpm) then truck b would have made more hp.
But yeah, big diesels are funny to watch when they ourtun cars that they are not supposed to.
-Mark
Old 11-21-2011, 04:18 PM
marc97taws6's Avatar
I'd love a new Duramax. I just can't justify the cost of it because I will never need to tow that much lol
Old 11-21-2011, 04:22 PM
MTN_Z's Avatar
-Mark
I have an LB7 and when it had one of the 90hp Edge boxes on it back in the day, it would still rip on your everyday ricer easily. It went high 14s with nothing else done at a track that runs slow. They aren't designed to be fast, but they can become so powerful they beat the air into submission and are pretty quick as a result.
Old 11-21-2011, 05:21 PM
LS1Tech Sponsor
Mike@Diablosport's Avatar
Our 06 LLY runs 14.0 all day with just our extreme tune loaded, everything else bone stock. Would go 13's if it could come out of the hole worth a damn (2.2 best 60' on stock tires, 2WD )
Diesels rock.
Old 11-21-2011, 07:17 PM
1992TsiAWD's Avatar
What all does a tune change on a diesel? More boost and fuel?
Old 11-21-2011, 07:27 PM
s346k's Avatar
Originally Posted by thunderstruck507
Those couple make the idiots with nothing but stacks and programmers think they're fast though, makes for amusement and some all you can rape redneck buffets.
there is A LOT of truth in this statement.
a guy i worked with was into diesel trucks and gave me **** all the time about his his buddy's cummins would decimate the ta. i blew him off repeatedly simply telling him to accept the fact that his buddy's truck, which had $20k in it, would hardly run with a stock ls1 (which, sadly, is still the bar, apparently...). come to find out, i had raced this truck earlier in the summer, spanking its *** repeatedly from slow rolls. after that he figured out what the trap speed portion of a timeslip means. 12.8 @ 101 < 13.24 @ 111 on the street hahaha.
Old 11-21-2011, 07:59 PM
RedHotG8's Avatar
I put a woopin on a diesel pickup today. The guy thought it was fast until I walked him like he was standing still lol. He got me off the line (torque) but he quickly ran out of horsepower to be able to keep up with me.
Old 11-22-2011, 12:08 AM
ls1 1990 VN's Avatar
And this was a guy in his standard crummy diesel who hole shot you big time....just think how you would have felt if his had been a tuned mother fukr!
Never underestimate the guy next to you.
Look at the diesel powered Le-mons cars, the diesel ocean powered race boats....they aren't powered by diesel for economy.
Old 11-22-2011, 07:18 AM
zz4camaro1980's Avatar
Originally Posted by assasinator
nope.
horsepower is the definition of work produced over time. torque is the measure of twisting force. any work produced over time IS horsepower. Horsepower IS what moves a vehicle NOT torque. strictly by definition.
torque is and instant value. it is spread across an rpm band for a series of instant values. the work (HP) that moves a vehicle in (calories/hp/watts) is the measure you speak of.
nice try at argueing dynamics vs. kinematics, but what I stated is still true.
Torque is the actual force applied that makes your car accelerate.
HP is a function of how much force is applied over a given distance and time:
"If a force is allowed to act through a distance, it is doing mechanical work. Similarly, if torque is allowed to act through a rotational distance, it is doing work. Power is the work per unit time. However, time and rotational distance are related by the angular speed where each revolution results in the circumference of the circle being travelled by the force that is generating the torque"
EDIT: Just remember, an object at rest stays at rest... unless acted upon by an outside 'force'.
Old 11-22-2011, 09:13 AM
thunderstruck507's Avatar
One the diesel ricers thought it would be wise to race a buddy of mine's ported/pullied/bolt on Cobra from a ******* 50 roll because his transfer case was fucked up or something like that. He bet a couple hundred bucks on it.
He needs to stop huffing the diesel fumes I guess. You don't pick roll races with a manual trans car that traps 125mph when you're in a 7500+ lb POS with the aero of a bulldozer and might be lucky to get some mid13s.
Old 11-22-2011, 10:31 AM
Mississippi's Avatar
Fact is yes a 6.0 gas burner pushing 35psi would probably rape a 35pso diesel burner but how much more does it cost to build a 6.0 to handle that kind of boost? A lot more. Buy a diesel truck for 12k and put 8k in it and run 12s in a 7500 pound brick or buy a gas burner truck for 10k and put 20k into building it to handle 35psi worth of boost so it can beat the diesel? Na. Diesel is where it is. That gas burner can be built to handle it yes, but it will never get 20+ mpgs, and 400,000 miles running like that. The diesel can. One of my buddies has a 98 cummins truck running low 13s with 380,xxx miles on it. No rebuild, and he's never touched the internals of the motor. You just can't do that with gasoline engines.
Old 11-22-2011, 06:44 PM
  #32
assasinator's Avatar
i dont care either way. im a devil's advocate for whatever position is in opposition to the majority.
Old 11-24-2011, 12:18 AM
  #33
ZFreie's Avatar
Amen
Old 11-24-2011, 09:03 AM
  #34
DiscerningZ32's Avatar
8 grand to run 12's?
In what way is that worth a damn?
Here's an idea, keep your trailer hauler... I don't know, hauling trailers... and race people in a car worth a damn.
And better yet, don't even buy a diesel unless you have to haul over 11,000 pounds.
Modern gasoline trucks are more than getting the job done.
A 2wd 3.5l ecoboost F150 can tow over 11,000lbs and gets 22mpg highway.
Diesel trucks are more efficient, but they are far more than most need and they are considerably more expensive than a 1/2 ton gasoline truck.
Old 11-24-2011, 09:10 AM
  #35
willizm's Avatar
^People don't buy diesel trucks to race people. It's usually on hauling/work duty for most and sure why not modify it a little to make it quicker. Besides, when a fbody beats a mustang it's expected, when a diesel truck beats an fbody or mustang it's humiliating and makes for so much more fun. I used to think that trucks wore worthless, but I've ran a couple and they can be stiff competition.
Old 11-24-2011, 09:23 AM
  #36
Yeah, that makes perfect sense.
It's the people that dump a **** ton of money into it to run 12's or 11's that leave me scratching my head.
Old 11-24-2011, 09:28 AM
  #37
1TFROT's Avatar
Originally Posted by TheHitman
I think what he's getting at is that all that torque at low rpms and not spinning the engine to maintain that torque at high RPMS isn't going to make you fast. Plus the fact that diesels are really heavy. You also have to consider that it takes a Diesel truck like that about 1000 ft/lbs to do a low 11 ET.
more than that
mine puts down 1040ft/lbs at the ground and only runs high 12s. can't tell ya how much fun it is beating a car that the owner thinks is fast and you walk on him with 7500lbs (or even give him a great race)
Originally Posted by willizm
Very true. 4x4 launches while building boost will pretty much out launch anything on most streets. Well almost anything
you were right the first time, they will
RedHotG8, anytime you want to have a little fun, let me know. my truck isn't blazing fast, but it'll hold it's own against many vehicles. it's fun either way
and thanks for the backup Will. glad some people appreciate power no matter what form it's in
Old 11-24-2011, 01:18 PM
  #38
Heater's Avatar
LoL,
Old 11-24-2011, 07:26 PM
  #39
usmc320's Avatar
If you want just one vehicle that meets a variety of uses, a diesel 4x4 doesn't get much better. I personally prefer to have a sports CAR for spirited driving. My diesel truck never sees full throttle.
Old 12-09-2011, 08:28 AM
  #40
whitedevilWS6's Avatar
Thanks for the sig quote, been looking for a good one
Quick Reply: Duramax Puttin the Hurt On Everybody
