LS2 GTO vs E60 M5
LS2 GTO vs E60 M5
GTO:
-180* Thermostat in Edelbrock High Flow Water Pump
-Idle Air Temperature Sensor Relocated to Air Filter
-Vararam Intake with Heatshielding
-Ported TB
-Fast 102 Unported
-OEM Heads
-OEM Valvetrain
-OEM Cam
-OEM Displacement
-Jet Hot Coated Kooks Signature Series Stepped 1-3/4 to 1-7/8 3” Merge Collector
-Catless 3” Midpipes
-2.5” Corsa Sport Dual Exhaust with X-pipe.
-3.91 Differential Gear Ratio
-3520lbs Curb Weight at San Antonio Raceway
M5:
-SMG
-Intakes
Discuss.
-Ported TB
-Fast 102 Unported
-OEM Heads
-OEM Valvetrain
-OEM Cam
-OEM Displacement
M5:
-SMG
-Intakes
Discuss.
good runs and i like the setup op. Clutch, alu flywheel, driveshaft, drag wheels, and a bit more weight pulled and you could have yourself a serious bolt on GTO that could upset some people. Probably drop another 150lbs with mods i just mentioned.
I was thinking a G-force CF Driveshaft and a Spec 3+ clutch with lightweight flywheel would be my next mods. Maybe coilovers if I have enough money. I can pull the rear and passenger seats for an easy 110lbs when I need to loose it too. 120 traps as a bolt on car is my goal.
Also an underdrive pulley and EWP is a must. Even if it only gets u 10whp... its 10whp you will need on the back half of the track.
Went back and did some math, pretty sure I can save get under 3450 from clutch, driveshaft, wheels, and coilovers.
