Ls1 Trans Am vs. 1979 Firebird
Did a few runs with friend a little while ago. Thought I would share with you.
His mods are Ls6 intake, Ported 853 heads, Ms3 cam, long tubes, cut-out, 4000 stall, A3, 3.42 gears, and the last time it was tuned was when it was a bolt only car
My mods are 355 SBC, Heads, cam, intake, long tubes, 3600 stall, A3, and stock 2.73 gears
The first 3 runs were 40-45 to 125-130
The last 2 were 10-15 to... well it doesn't even matter since they were not even close
Yes, it looks like I'm getting ready to drop a deuce in the video. I didn't have my sunglasses and it was real bright out
http://youtu.be/mwM9bxOZpkk
Enjoy
Enjoy
The car made 368rwhp/342rwtq (mustang dyno) in second gear on a 100 degree day. So I've been told they might be a little low. No track times because of the rear end gears and tires basically making the car **** it pants til I get rolling and close to the powerband
So it can't be used as incriminating evidence
3.73's WILL be back there... with a 275 tire... and some nitrous
It will happen. Just have all kinds of other things that are claiming my funds right now.
i had a built 350 in an old truck once. it had 2:73's. when i swithced to 3:73's no word of a lie it dropped at least a full second in the 1\4.
These are older (when it was a v6) and it doesn't look this good anymore
Thanks everyone!
Hmm. Let's see if my ears still work after a 10 year drought of not working on a SBC: 10 to 1 compression, 238 duration .550" flat tappet either hydraulic or a tight lashed solid cam on a 110 LSA, roller rockers, 12 deg. initial timing. Headers aren't 'tinging' like Hookers and the flange and bends look like my old headers so they Summit headers? 2 chamber 3" flowmaster?
What kind of heads to pull that kinda power? Dart?
Thing runs great btw! Having gone from 2.73 gears to 3.42 in my '78 Z28 I can attest to the huge seat-of-pants increase in power you will see. Should be enough to keep the LS1 from coming around you. Oh yeah, I'd pick up a base model V6 manual brakes master cylinder if I were you, they worked great even with the bigger '81 disk brakes I put on mine. Awesome pedal feel with totally daily driverable pedal effort.
It's not that nice in person, but thanks man
I guess I should say it's not a stock tune. It was last tuned when it was a bolt on and M6 car.
Very, VERY close. I am impressed you could pick that up from the video. Compression is 10.5:1. The cam is a solid roller with the lash at .016/.018, 236/242 @.050 .564/.570 lift and then I put 1.6 roller rockers on. The LSA is 110. Timing is locked out at 35 degrees. Headers I actually got for free. They are a set of hedman headers. Exhaust is 3 inch x pipe with 3 inch Magnaflow bullets and dumped at the axle. The heads are older 195cc trick flows with 64cc combustion chambers.
I really can't wait to rebuild the rear end and make the car MUCH more fun. My first gear runs up to about 60-65 mph, and second gear is good to 120-130 mph, third gear... well I know what the math says but I am never going to find out. I hope the gear change will help keep the cars momentum going.
This car was actually a v6 but it does have power brakes. How much weight do you think it would save? I am also ditching the power steering for a manual steering rack.
