89 5:0 5spd vs 97z28 6spd how would i do?
[quote=LT1Mike] ok his mods are ported gt40 heads, 1.6 rr, 1.94/1.60 valves, gt40 intake mani, 70mm tb, 75mm maf, 24# inj, custom cai, shorties, offroad midpipe, magnaflow catback, solid motormounts, a/c delete, smog equip delete, electric fan, 3g 130a alt upgrade, ministarter upgrade, tremec 3550 trans, ram hd clutch, steeda triaxe shifter, quickrelease clutch quadrant, firewall clutch adjuster, 3.73s, walbro255 fuel pump, 5 lug conversion. I think thats it lol and cant forget trickflow stage 1 cam. mine are
short stick, 52mm tb, ngk tr55s/wires, 1le elbow, ported lt1 heads, valves 2.0/1.5, 1.6 rr, 3.73s, stage 2 spec, flywheel, magnaflow catback w cutout, high flow cat, edelbrock shorties, ported maf, ported intake, lingenfelter cold air, subframe connectors, reinforced torque arms, computer tune ran 319rwhp/338rwhp before tune and cutout, through a m6.
how does it look for me in this race? its happening next wednesday. im just curious on outcome.
Thanks
Thanks
My thoughts exactly. In my experience guys who post every single little mod including things that really don't effect the cars performance, like certain motor oil or certain spark plugs, usually do that for "hopeful horsepower". Go to a non performance vehicle forum and youlll see that all day long.
Sorry but no, if it was a gt40 head only car maybe, there have been many gt40 headed foxs that have dynoed 260+, with PORTED gt40s and a tfs1 it prolly makes 280+ and is good for mid to low 12s depending on the setup. If the car runs good, and doesnt weigh much youll be chasing.
notsrs
so a stock 5.0 with just a gt40 head makes 250whp? Im well aware what can be done with an old sbf. Im also well aware of how easy it is to mix match parts and make **** for power on an old small block. If i told you my friend has an NA 306 that made 458 whp with hydro roller cam on 93 octane. Would you believe me?
Pretty sure this car isnt just a "stock" 5.0 with gt40s thrown on, it says PORTED gt40s, which im sure has full exhaust at the very least along with a tfs1. I came from the 5.0 world, and still own one and i very much know what they are capable with "junkyard" parts.
Its quite obvious you arent "well aware", if you would like i can find you numerous links of gt40 headed cars making 260+rwhp, and one making 350+rwhp (race motor).
Like i said, the heads arent the problem in that build.
Pretty much agree with the above comments on if he has traction it'll be you playing catch up. I raced the same fox from the cwarta video and the fox jumped me out several lengths but it was a rapid pull after that as I reeled him by top of 2nd.
You didnt answer my question. And FYI, when did I say anything about the HEADS being the reason this car wouldnt make big power? I also know what they are capable of with stock parts. Same guy who built the 458whp 306 has a stock parts 302 that makes 317whp. Stock untouched heads, stock cam, stock rotating assembly. Its a class car.
