Bolt on GTO vs Bolt on 5.0
2006 GTO (A4)- K&N intake, Fast 102, LT headers, Catless exhaust, Tune.
2011 5.0 (3.31's)- JLT intake, LT Headers, Catless exhaust, Tune.
We ran when we were both basically stock, dead even till 100.
We ran when I was stock && he was intake, tune, exhaust && I got destroyed.
We got 1 run in today, from a 30 roll... He honked, we both take off... I spin thru first && some of second... At around 90+/- he had half car length between our bumpers...
He told me 5 minutes later he started in 2nd gear && it hooked.
Yeah he started in second && dead hooked... I started in first && spun for little after it hit second...
He was steadily pulling but he wasn't walking away by any means, slow pull..
30mph in 1st in a auto? Ouch, that's a hard spot to run from if you can't dead hook it. Let me guess on how it went: you were holding 1st gear, car spins into rev limiter then since it's already spinning continues to spin in 2nd leaving you a car or so back from where you should be in you had traction. Unfortunately even if you dead hook it, the trans doesn't like doing the 1-2 shift that quickly and normally hits the rev limiter before shifting right?
20mph is your best spot if you can't do a dig, and you HAVE TO get yourself some tires that have enough traction that you can use 1st gear at WOT (assuming a quick roll into WOT and not a stab of the pedal).
I'd highly recommend some better tires first, with a 3200-3600 stall converter as a must have next mod. The tires alone will work, but you can kiss rolling burnouts, or any kind of burnouts goodbye if you don't do a stall converter. With a proper stall converter you will find your car is a whole different beast, nearly as much fun as a stick shift if you like screwing around and it will get rid of the A4's notorious dead spots too.
Ever dreaded running from a 35-40mph start? Hate it when you punch the gas at 72mph and it refuses to drop down to 2nd gear? When you are in the 5-20mph range and you punch it, do you find yourself relying on the initial torque hit to spin the tires a bit so you don't have to wait for the rpms to reach peak torque? All fixed with a 3600 stall converter.
Small Print: a 3600 stall will take a chunk out of your intown gas mileage, and requires a good trans cooler WITH FAN to keep your temps in line. Also makes driving in the rain, umm, "entertaining" if you don't exercise strict throttle control.
My car actually pulls pretty hard from 30 dropping into first... But yeah it spins hard, shifts into second && continues to spin just as hard (today was warm so during this race it didn't spin as hard as usual in second)...
I planned on a stall but my trans has 111k && I don't think it would stay together even with a big cooler... I'll wait till my trans dies && my warranty pays for a new one.
Picking up a nitrous kit tomorrow.
Yeah I will be in OC, what's up?
Yeah his car usually lights the tires up even at 50+ rolls... This weekend we had mid 50* weather so the roads were warmer ... If he's in his power band (30mph -first gear) he would have spun hard...
In all honesty, even if both of you hooked perfectly that 5.0 should be walking out at least 3-4 cars on you from a 30-100 roll race. He probably has 60-70rwhp on you, is lighter, and has better gearing due to the 6 speed: you have more midrange torque, true, but it's not enough to overcome all of his advantages.
Stock for stock a GTO has a chance against a 5.0, but bolton/tune to bolton/tune the 5.0 brings a AR15 to a pistol fight.
His setup should be a high 11's/low 12's at 116-118mph car. That's realistic numbers, not youtube hero numbers. Yours should be a 12.7-12.9 at 108-110mph setup if you both can hook. Your gonna need a cam to reach him if he can drive his car to it's full potential: obviously something is amiss, but I want to be sure that you aren't thinking your car is faster then it is, nor that 5.0's are slower then they are.
Here's a useful, time honored and proven formula for car lengths: 1 car length = 1 tenth of a sec = 10rwhp = 100lbs = 1mph. That's for a full 1/4 mile run, assuming street cars (11 seconds on up) that have decent traction. For a 30-100mph run figure that you should cut that half which means 3-4 car lengths is generous. BTW his back bumper at your front bumper means he is one car length ahead of you. Alot of guys don't count that, but IMO that's stupid not to count that.
***Repost Police***
You realize he owns an LS2 GTO...right?
