f20b hatch 2.0 13sec vs VW 1.8t mod 20 psi 12 sec car
i went to the track ran into this groupe of cars
ran the VW
I ran 13.6@104 and 13.7@103
with 175/65/15s 2.2 60ft my car is a stock 2.0 with cams and a 4.92 gear full weight 93 civic.
the vw had I/H/E front mount intercooler possibly gt28 on 20 psi guy didn't want to say VW was going low 13s hight 12s with a bad 60ft on street tires
ran the VW
7 Second Club
Good runs!
these high comp motors need to breath well and 2.5-3.0 pipping no cat
ppl always assume you have a 15 sec 130whp when it comes to hondas
my seteup is capable 115+ mph mid 11.4s or lower with with more work
Ima make this go high 11s out of a non turbo 2.0L with a mild 12 comp pistons stock rods just a ported head the pistons and cams bring the weight down to 2250 pounds with me in it it can go as low as 2000 pounds with the driver.
simple solution stock exhaust with a 3inch E cut out tune it for the E cut out run it shut and it will sounds some what normal
But I will try to reply so you can understand
I didn't get mad when you asked what car I drove
I just thought it was cute how you typed it out for sure I wouldn't take your car even if it had 500whp for sure I would much rather have any stock LS1 or stock V8 Mustang for sure DR heads up run against me from a dig would make you look stupid
not on the HWY
Just curious OP, how's your setup capable of picking of 12+ mph and well over a second with a little more work? It would barely run low 13s now if you had a good 60 ft.
Couple of points...
1. What the **** are you doing blasting through rush hour traffic like that?
2. The VW denied the **** out of your ricer flyby attempt.
3. Your car sounds AWFUL. My car makes 3x the power yours does and you can't hear it from 10 ft away, buy a ******* muffler.
Couple of points...
