E85 pullied Cobra vs E85 CJ Coyote vs Cam only Z
Good races tho op! Loved that c5z race. I'd love to find a nice c5/6z around me to get some good runs in with. I've always wanted to race either one but never find any interested.
mt82's are just garbage. Every once in a while you'll see someone with a modified 5.0 and they'll never have an issue. then theres cars like the one in the vid that go thru a crap ton of them. lol.
Hows that pullied combo work on pump gas and the street as far as heat soak?
On the street the setup wasn't bad tho. If I give the car a minute or so inbetween runs I dont notice or see any difference in how the car pulls. If you'd do it with e85 it'd be even less of an issue.
I try the 6lb lower. I made 18.4lbs and was having pumps problems since I change to some new stock pumps I never went back to try it again and wanted to make sure it was safe and getting enough fuel so went back to just a upper. I chewed up a new belt On the way home on the 6lb setup and squeak was horrible.
