Street Racing & Kill Stories Basic Technical Questions & Advice
99 ls1 trans am (weld wheels)
Old 11-14-2015, 07:26 PM
Bobby Schmitz's Avatar
Default 99 ls1 trans am (weld wheels)
So you guys are always the site I come to for questions I have but I came seem to find an answer to this question , my car is basically stock and I want to start building it but i want weld wheels for her and they gotta,be black so I walk reading on here I can fit 315s under the rear and was wondering what size rim I would need? I think I would like 15x10 or 11 but don't know if the 315 will fit a 10 rim oh and what kind of back spacing do I need? Any help would,be appreciated thanks
Old 11-14-2015, 07:28 PM
NateLS1Mustang's Avatar
Wrong section.
But I'm sure someone here will answer your question soon anyways.
Old 11-14-2015, 07:46 PM
Deeohgie69's Avatar
Scroll down a little, it's right at the beginning with all the info you need.
https://ls1tech.com/forums/wheels-ti...must-read.html
Old 11-14-2015, 08:48 PM
Hey sorry about being in the wrong page, I took a look at the chart you offered , thank you, also how am I suppose to know if the wheels and tires will even fit the car without rub?
Old 11-14-2015, 08:57 PM
Deeohgie69's Avatar
It seems like it's hit or miss on here with 315's if they'll rub or not. Most likely you'll have to use a bfh and massage the inner wheel wells a little, but I'm not sure if you'll have to roll the fenders or not. You may need an adjustable panhard bar to center your rear end if one side is closer to your fender than the other. If you plan on lowering your car then it will be a must. Good luck!
Old 11-14-2015, 09:49 PM
big hammer's Avatar
With a weld RTS I believe you need a medium pad height for a 15x10 and 7.5" back spacing
Old 11-14-2015, 09:57 PM
Deeohgie69's Avatar
^^^ I believe he's right.
Old 11-14-2015, 11:52 PM
What do you mean I need a medium pad height I'm a noob at this learning as I go.
Old 11-15-2015, 01:04 AM
Its Stock's Avatar
Lmfao
I really do love your ability of coming up with names on a whim.
Old 11-15-2015, 08:50 AM
big hammer's Avatar
The pad height is so the rim can fit over newer, larger brakes.
Many weld rims won't but some of the newer styles like the RT-S will with the proper pad height
Old 11-15-2015, 04:41 PM
Nick.H's Avatar
Wow is Jake back already?
Why hasn't this thread been moved yet??
Old 11-15-2015, 05:15 PM
2003Cobro's Avatar
Jake is such an embarrassment to all humanity.
Quick Reply: 99 ls1 trans am (weld wheels)
