Nitrous 5.0 vs. LS3 Cammed z28
#41
You can do it. ....you have plenty of power. You are loosing a pile of et on a real street tire. You still on 10 bolt?
Btw.....your ls3 has the same dimensions as a ls1.
Yea h/c ls1's are/should be around 490 these days for good ones. My ls6 was at 430 or so.....i would think ported heads and a decent cam would pick up 60whp in 2016. Then you have the ones that won't any more power than a bolt on ls6.
With out knowing your entire build I'm sure there are few things you can do to go over 500whp. Redbird was at 450 with a bolt on ls3 and was looking for 470 before he sold it and gave me blueballs.
#42
You can do it....but you're gonna have to turn it harder or pull some gear out. And get you a good clutch.
Do you have a dyno sheet you could post? I'm kinda curious about your power curve.
#43
LOL. It is a shitty clutch compared to the higher dollar ones. Trying to run 10s like you Hio.
Thanks! I had a shop do it for me. I believe the heads and intake are bigger than an LS1 so there is very limited room now. Spark plug 8 has to come out from under the car.
H/C LS1's are making 490? I thought they were more around 445?
It has a pretty mild cam in it now so drivability is nice and it makes decent power for what it has
#44
#49
#51
#55
Cool story bro. Why don't you go make a thread about how you feel?
#56
It's a shame they didn't run it on out to 7k atleast. You have damn near about 500rpm of peak power there. Thats pretty good.....should for sure be shifting past 6600. A little tinkering and some this and that and it will be a different animal.
#60
