i really should. ive broke so much **** for years on my cars im paranoid something is going to happen.
Originally Posted by marc97taws6
It's a stock car dude. You'll be fine
Yeah, you should be ok. If you are on street tires, just be careful with wheel hop. That is an IRS axle killer. Best bet overall would be to run a drag radial. Manual cars are definitely more of a handful at the track vs auto. especially on street tires.
1les have stronger half shafts if i remember correctly.
i would hope aired down F1s with a moderate launch should hook decently.
Dont run them too low on pressure. Street tires tend to cup inward in the center when air pressure is too low causing less contact patch. I would'nt run a street tire any lower than 28psi.
Just don't launch it at 3k on the stock tires. That resulted in the only 1le I've ever ran running 9.2 in the 1/8th. Dude was an idiot.
