Street Racing & Kill Stories Basic Technical Questions & Advice
Srt vs 2002 camaro
Old 05-25-2016, 11:22 PM
thumperz28's Avatar
Default Srt vs 2002 camaro
So this guy has a 2006 chrysler 300 srt with the 6.1 and he says he can walk my z28. I was wondering the predicted outcome of it. I have a 2002 z28 6 speed monster stage 3 clutch with lighter flywheel, tick perf master cylinder . Texas speed longtubes and X pipe, Slp intake motor is pretty much stock except a tune. It makes about 360 rwhp on the dyno. The 300 is bone stock to the filter. I'm just curious as to what would happen.
Old 05-25-2016, 11:46 PM
Mappinsj's Avatar
You will hurt his feelings
Old 05-26-2016, 12:30 AM
hugger1975's Avatar
^/thread
Old 05-26-2016, 01:52 AM
Nick.H's Avatar
He will go home sad and have an angry beat off sesh
Old 05-26-2016, 06:10 AM
408-99-f's Avatar
I guess that's a possibility
OP you should beat him unless he is hiding somthing significant, or you screw up the pass.
Now post up the race when it goes down, there is a bench racing section on here FYI
Old 05-26-2016, 09:03 AM
thumperz28's Avatar
I've already invited him to the strip because he wanted to race my built corvette. He never showed. Only time we've ever "raced" was he was acting big because he was pulling on my dodge pickup on the highway. So ill try to pressure him into it lol
Old 05-26-2016, 10:11 AM
Poppacapp's Avatar
^^ this x 100
Old 05-26-2016, 11:55 AM
MACHXLR8's Avatar
Dig or roll? Are you on a tire?
You will slap him around pretty good on a dig or roll as long as you do not blow the tires off.
Old 05-26-2016, 12:12 PM
thumperz28's Avatar
I'm on 275/40/17 street tires in the rear need to go with I little larger but it'll grab pretty good just have to feather the throttle a bit
Old 05-26-2016, 01:57 PM
Blownbayou's Avatar
360 RWHP??? That is strong for those mods. I made 349ish when I had about the same mods. Bust him up
Old 05-26-2016, 06:26 PM
willys srt8's Avatar
Don't sleep on him or he will hurt your feelings. I ran 12.85@108.5 with a DA of +1872 bone stock on stock tires. Once I was I/E/T, I made 445hp at the wheels on 93 octane. My base line was 405. I've been beaten by much slower cars and beaten much faster cars at the strip due to mistakes on both sides...
Old 05-26-2016, 08:07 PM
thumperz28's Avatar
It will bust out mid to high 12s. It's just the clutch grabs hard and if I get into the throttle heavy it'll send me spinning. I was extremely surprised at this I figured it would be running slower.
Old 05-26-2016, 08:51 PM
I don't have a tuned dyno sheet. It went with the car but I found the baseline.
Old 05-26-2016, 10:39 PM
Poppacapp's Avatar
I got gapped at the 1/8th mile by a Superbee this past Sunday. He only had a Whipple/other mods and ran 6.85@102 tho...
Old 05-30-2016, 12:27 PM
Marc 85Z28's Avatar
Both of those dyno numbers are about 40rwhp too high.
Old 05-30-2016, 06:46 PM
Prototype007's Avatar
You've got this, OP.
Old 05-30-2016, 07:14 PM
Check posted dyno sheet for baseline. The car has been a subject of hurt feelings on this site for years.
Old 05-31-2016, 09:08 AM
Jay z28's Avatar
You made 405rwhp with a 6.1 car? Stock? That may be the absolute highest stock hp I've ever seen for one of those.
Old 05-31-2016, 11:33 AM
Marc 85Z28's Avatar
I saw what you posted. I understand what it represents, and you very clearly do not.
1. Generous dyno.
2. Uncorrected in favorable conditions.
Again...40rwhp too high.
Edit: A quick search revealed this:
https://ls1tech.com/forums/street-ra...l#post11494594
you should talk to Immo over on the charger boards. several of us were at DTP getting tuned the day he put down 441hp with 4th gear pulls. as far as i know he was the only one who did 4th gear tuning. i baselined at 405hp/410tq @170 mph in 4th w/intake and xhaust. tuned in 3d due to over speed errors w/baseline if 378hp/376tq and ended up with 404hp/395tq in 3d with my timing off 2*(bad gas). that translates roughly to 430+hp in 4th. i went back in Nov. for a hp competition and dynoed again without the tune @ 32* temp and put down 412hp/425tq w/4th gear pulls. i accidently for got to reprogram after maintenance @ Dodge and didn't realize till after the first pull and low #s. sure enough the ole Predator said "last tune written original backup". but this is the second eng in the car and the SRT guys brought the new one and installed it themselves or so i was told. one can potentially gain 40whp w/ just a u/d pulley or xhaust, intake and a Predator and that should put you somewhere around 415whp depending on the combo that is used. which would explain why a CMR tune is so much better than the canned tune. if you were to buy the SRT-8 eng as a crate eng they are conservatively rated @ 450hp. a good tune to milk the eng and some minor mods will fix that. i could always e-mail you my tune but i don't think it would work for ya.
And this:
https://ls1tech.com/forums/12-second...l#post11761098
THX everyone. violent celerity i don't know. i never got the chance to run it bone stock. sorry
AND THIS:
https://ls1tech.com/forums/street-ra...l#post11613128
temp was 82.9*, humidity was 58%, 75ft elevation, DA 1841, and the track sucked if that gives you enough info to decipher and critique my runs. corrected numbers were 12.92@109.647. I’ll have all the slips as soon as I figure out how to convert them to digits. thanks for the advice guys if you are here.
my best run looked like this
RT .2003 best was .0702
60FT 2.0586
330FT 5.6853
1/8ET 8.5845
1/8 MPH 85.31
1/4ET 13.1964
¼ MPH 107.30
That 405rwhp "baseline" of yours was with a tune, intake, and exhaust. That is the setup that ran 12.8 @ 108 two months later. Did it really run that number, or is that what you corrected it to? THAT is a bit more realistic. Why lie?
Old 05-31-2016, 08:18 PM
odthetruth's Avatar
Only a whipple... only.
Agreed.
Agreed.
1. Generous dyno.
And this:
AND THIS:
SLAUGHTERHOUSEEEE!!!!!!!!!!!!!!!
Quick Reply: Srt vs 2002 camaro
