6g vs lbo br0 (neither my car) good race
#121
Looks like all ypur numbers are fudged up to. How can a knowledgeable car car misrepresent them so much and so often after hearing them over and over and over?
Weight was 3250.
So are you saying i shouldn't be able to out launch a 12seccar?
130mph traps wasn't seen in a bolt on ls6before i did it either. Now what?
Weight was 3250.
Omg, I can't believe I have to explain this. I didn't say you shouldn't be able to out launch a 12 sec car. All I was getting at is there's nothing funny about a lower powered 12 sec car being able to launch very quick off the line and have a low 1.5 60', that's nothing out of the ordinary. I was just replying to this comment.
#122
Showing your ignorance again. That was close to pump gas boost for a 8.4:1 motor. I actually ran it against a few cars with the same boost on the pump tune. Poor Doug forever stuck in 11s with his built racecar.
#123
Wow, one number is off and that means all the numbers are? How can someone who thinks they're so smart skew things so much? For some reason I thought it was like 3180, I was fairly close, I'm ok with that. If I remember correctly you had 3.90s and 3.73s in the car, just not sure which during that time. I'm not like people like Jake, I don't stalk people on the net to keep uncomfortably close tabs on them.
#124
Maybe i had a poor reaction because i had a poor reaction. Didn't think if that did ya?. I already said the other lane treed me.
Yet no explanation to how i got in front of a car that 60' a 1.4x. Even according to your fake math that would be impossible.
Hell i had all my dd stuff in the car and the jack/spare.
You making **** up just shows how pathetic you are.
#127
Your responses are funny when someone points out one of your dumb comments, like the one below, that makes no sense. You try to turn the table and make them look dumb. Doesn't work. It's only funny because of how high you put yourself on your pedestal.
#128
So ypu made up numbers and expect people to believe them vs actual timers......lol......good to know hillary.
So you're talking alot of **** about a car you remember little about.
So not on pump gas. Note taken.
Why in the world would i change my rw for raceday? Who does that unless they want some hero number they can't replicate?
#131
#132
7 Second Club
#133
Never seen anyone rage as bad as s550 5.0 owners... it must be hard to be the lowest man on the totem pole, in the muscle car wars.
#135
7 Second Club
The only thing I remember when it comes to Hio / Pappa and rage, is the terroristic tactics, death threats and entire thread deletion by the 5bro.
#136
The only explanation then is it did it......or i woulda never ever been in front or even beside that car.
The car i was running on the 1.26 6p' was a supercharged/e85 coyote with supporting mods. Are you saying now that the car supercharged coyote don't run as hard as the one you posted?
Lol... the only thing that's funny are your responses because your ego is too large. Your car cutting a 1.2 makes no sense and you know it. But that's beating a dead horse.
I don't put myself or the car on a pedestal. It woukd take setting it up for a glory run on some of these super fuels to do that. Not driving it there on a rain worthy tire with pump gas in it.
Lol.....what other gases did you have running through it?
#137
Here's what you aren't getting doug. When that beam holds, the timer hasn't started. You are moving before the clocks.
You moved before the 5.0 but the clock didnt start. Got it? That's why your reaction time is worse than his. You did not out 60' a car going 1.41.
How the **** does a car trapping similar to your go .07 slower through the 60 and end up .8 faster while only trapping 3 mph more?
#138
Hio car is capable of 10.7s. Probably faster than that now. I been around it,in it unlike anyone else here.
I personally think it ran 10.7 on that pass. I have had 60ft timing errors at that crap track many times and ET and MPH were normal. Something tripped the beam is what I think. Reason for his ET all over the place that day is his tires(drag radials on a stick car is not ideal). With a real tire on that car it would have went 10.6 I am sure.
#140
