Cobra Kai Doing Work
#61
Are you trying to say the cobro can't carry the rear end it came with?
Next you'll want a weight break because of the iron block. How bout a weight break for the entire termi set up with adds nearly 300lb to a car vs a aluminum na ls.
#63
Not a stretch at all.
You take the weight of the passenger and the weight difference of the two cars also into the equation, just as you would take the power difference of the two cars into consideration.
Gearing, traction also play a role as well as the drivers of said cars.
Much easier to compare apples to apples when it's apples to apples.
#64
Someone say real world experience with terminators? Back when my **** made a Beasley 490hp. Against my buddies 03' which at the time was the highest hp stock blower car. I don't remember exact numbers but it was like 550ish. Ran 7.teens @101. It was no slouch by any means. But it still got drug by a subpar engine combo
https://youtu.be/3FdKllLrfMg
#65
Wouldn't apples to apples be 2 supercharged v8s running at the same boost level? How do you think those apples woulda worked out?
We're talking a na v8 vs a aftermarket boosted v8 here. That will never be apples to apples.
#66
Leaving the passenger out would not have stopped that train.
#67
#68
Hey let's see how your turd runs na.
Misread stock blower mang....nbd. you should see what i do to termis on the stock blower with a sra.
Not making anything up. Sure it matters how it's made. One can make the power n/a the other just can't. If i walk up on m car and it runs x time and it's boosted then i walk up on c car that's n/a and it runs the same x time then c car is more impressive.
#69
Lol Stip?? So what you really meant is watch what happens when i pull the motor tear it down, build it up with a bigger and stronger motor, then put it back in, then do a complete blower fuel system on the car, then put the blower on it. Then we will see how it stacks up to your near stock pullied cobra. You have now reached full retard. Maybe you started doing weight reduction on your brain??
#71
#75
Why would i have to build a ls to make the power a cobro makes? Been proven lots they can do that and more. How bout you try and make that modular make the power a ls does n/a. You know when the engine actually had to breathe on it's own.
**** last time at the track when i ran with my car there was a guy there. He had a t/a. All he would say is its big...with a f1 blower....it's big. He looked at the back of a ls6 camaro till the last 100ft when he pulled even. Is that a direct comparison?
Very much the point
I look at all angles. 2 engines running at different atmospheres is not direct.....furd guys will argue that. Cubes?.....well gm don't make a 4.6 performance engine. Wtf am i supposed to do about that.....so they cry cubes. Nothing stopping them from building /boring/stroking one.....except they know it still won't keep up to a ls with the same "effort". Key word right there to be fair i expect the same "effort". That means if you build i build. As where furd guys expect a gift like they should be able to build what they want to just "equal" the ls.
Anyone that see's it any different than that is showing favoritism.
#76
Lol...wow... like a ******* near stock pullied cobro is that fast. Yours never left the 12s.
Your original quote for referance below
The answer stays the same it will blow up. Poor cheby.
#77
7 Second Club
hahahaha...I knew it was only a matter of time till Hiocrew came in here crying like lil bitches.
PS. Takes a built 408 with a 88mm terbo to give me a good run at the track. 5.3,4.8 and 6.0 don't come close...so there's that.
Just got a baby 281 with an 80mm in my cobra...damn huh?
#78
My car is far from hacked. When i do post pics of the comments are usually more about how clean and niceit is. So you can shut the **** up about that that and stop lying .
More lying about 11s.....do i need to post the vid again for the 100th time of it goin tens in full street gear?
And no matter how you slice your furd was not gonna get there n/a
After all the crying when it didn't go 10s it gets more now that it does....that makes me lol at the bitches crying.
#79
7 Second Club
#80
