Mavn went 10's first pass 🤘🏻 - Page 3 - LS1TECH
Street Racing & Kill Stories Basic Technical Questions & Advice
Thread Tools Search this Thread
Old 02-06-2017, 08:05 PM   #41
Dimeomboost's Avatar
Quote:
Originally Posted by 408-99-f View Post
Nice work op, my 408 stick car went 10.9 at 129. 1.5x 60'. I could have got it faster but I went to a turbo auto car. I really miss it N/A part of me really regrets the switch. My car had am lot more in it.
same here I got away from my 406 s10 before I knew enough about fine tuning and suspension to really see what it could do but I probably had it at 75 percent at most would love to try it the right way this time
Dimeomboost is offline   Reply With Quote
Old 02-06-2017, 09:07 PM   #42
marc97taws6's Avatar
You are the only person I've seen go FI and actually dislike it.
marc97taws6 is online now   Reply With Quote
Old 02-07-2017, 11:47 AM   #43
islander033's Avatar
Quote:
FI takes more attention to run than NA. Fuel, toon, ect. It's not for everyone.
islander033 is online now   Reply With Quote
Old 02-07-2017, 01:39 PM   #44
Tyler Lee Lee's Avatar
Quote:
This!
I actually enjoyed going to the track more when my car was N/A. With all the extra baggage that comes with a F.I car, it becomes more like work.
Tyler Lee Lee is offline   Reply With Quote
Old 02-07-2017, 09:00 PM   #45
408-99-f's Avatar
I don't dislike it, I just need more time with it I guess. I had alot of attention to detail in that car and it ran exceptionally well. Wasnt done but was getting there. Op's car reminds me of it.
I am getting used to the new setup, I just need it to run good for what it is first. Not avrage, better than that.
I also want it to 60' good too, not just a roll turbo car.
408-99-f is offline   Reply With Quote
Old 02-08-2017, 06:20 AM   #46
assasinator's Avatar
with FI there is no advantage to cubic inches when you run into someone using the same power adder.
a 281 and a 406 make exactly the same power with your 78. the turbo flows the same for any motor built to handle it. your car chasis has to be better.
60' is a converter/transbrake chasis and boost balancing act. leave at 8 and ramp it up at a rate your setup will handle. if you cant get a killer 60' you need to add boost fast. it will still back half. a simple boost controller or running on a waste gate will not work.
look at how high dennis carries his front tires. if he wheel stands it he doesnt run 8.30's.
assasinator is offline   Reply With Quote
Old 02-08-2017, 06:24 AM   #47
plug temp and gap. i run .024" gap. even with good coils it blows out at 16psi with any more gap. lots of things to get right.
Old 02-08-2017, 03:25 PM   #48
Quote:
Shelby gap is 0.028 stock coils
Cobra gap is 0.018 LS coils
Never seen any blow out on either.
AFR, fuel level, timing at wot, proper cooling for AITs...
Just more things to consider to keep your motor alive when FI.
Old 02-08-2017, 04:44 PM   #49
408-99-f's Avatar
I have a simple manuel boost controller right now, I have been doing my homework and looks like I might go with a Boost Leash. I also have a stalled auto, I had been trying a slightly higher stall aprox 400 RPM than what people say I should, (But people say alot of things) to help with it leaving good. It still makes good power up top though. But I need to go to the track, make some passes see what's going on. Swap converters and go back and do it all over again at diffrent power levels and see how it reacts.
I might go to a diffrent head too, I am in the middle of revamping somthings since we are buried in snow.
Old 02-08-2017, 04:51 PM   #50
408-99-f's Avatar
Ya I am doing all the research I can on tuning for FI. I am almost thinking of putting a turbo on one of my trucks just to practice on lol.
And .018 is tiny lol, some cylinder pressure there. Are you running a Pyro meter on that car for egt?
Old 02-08-2017, 04:57 PM   #51
That 0.018 was spec'd by accufab to be able to run 30psi. Only been to 21.6 psi peak so far in 1:1 gear.
No egt sensors on the cobra.
Old 02-09-2017, 03:22 AM   #52
oChristiano's Avatar
Yep. My N/A cars were hop in and drive more or less. My turbo car was more of a wake up call on how it isn't as easy as the internet says lol!
oChristiano is offline   Reply With Quote
Old 02-09-2017, 09:33 AM   #53
sweet99ss's Avatar
Turbo cars take a little more time to setup and make them "hop in and drive" cars, but I feel just as comfortable jumping in my turbo car for a long trip as I do my 408 car... Last year I went to the track twice with my turbo car in the same month. 12 hour round trip beat the **** of the car and drove it home!
sweet99ss is offline   Reply With Quote
Old 02-09-2017, 10:35 AM   #54
no egt's for me either lol.
my spec on .024... when the blowout stopped, .024 was the gap...at 16psi. im quite sure that at 20-25psi it will shrink.
when you swap to that electronic boost controller, and your stall will support your leaving rpm, that is how you will dial your 60'.
all that stall bullshit will be in the past. your converter will flash to whatever stall the torque decides it is. Dennis is the hero here, but in my car the converter is not stalled very high. its just for tuning until the glide goes in, but as long as it supports 8psi on the line its all i need.
no wheel stands. i haven't seen views on dennis' 300', but im willing to bet one tire is just peeking a gap under it.
IMO
Old 02-09-2017, 10:44 AM   #55
sweet99ss's Avatar
I started having spark blow-out at 11psi when my br7ef's were gaped to .032. Re-gaped to .024 and now I don't have any issues. Bought to turn up the boost with a bigger turbo and more fuel so we will see if they hold at 15psi
Old 02-09-2017, 11:10 AM   #56
... its just for tuning until the glide goes in, but as long as it supports 8psi on the line its all i need.
no wheel stands. i haven't seen views on dennis' 300', but im willing to bet one tire is just peeking a gap under it....
8psi at 4500rpm is all my shitty suspension (thrashed spec d shocks/struts and stock rear GT springs) can handle. lol
The car pulls 1 wheel, 1 inch for 1 foot so far.
Would like 6 inches with 2 wheels for 60ft one day. Doing suspension this winter to see if 1.1x 60ft is possible with this car at my low prep tracks.
Old 02-10-2017, 11:19 PM   #57
02sunsetorangeZ's Avatar
nice runs. go with diamond stage 3 clutch. You won't hurt it.
02sunsetorangeZ is offline   Reply With Quote
Old 02-10-2017, 11:23 PM   #58
******* turbo guys. I gap my plugs at whatever the factory gap is.
sw07gt is offline   Reply With Quote
Old 02-11-2017, 07:20 AM   #59
Quote:
You might get away with that until you use man jets...
Seen this on FB today, 400 shot on TR6. lol
Old 02-11-2017, 03:41 PM   #60
ajrothm's Avatar
**** man! Who the **** sprays on a TR6? Or a TR anything for that matter.
I guarantee you his pistons look worse then the plugs. SMH..
ajrothm is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Mavn at the track . Finally . Mavn Street Racing & Kill Stories 53 01-30-2017 04:47 PM
Cant get Clutch??? Mavn Manual Transmission 1 09-13-2016 06:07 PM
TX2K Roll Racing - Mavn Mavn Street Racing & Kill Stories 32 04-09-2016 07:35 PM
Mavn first Death N/A.. Vs SneakySnakes Mavn Street Racing & Kill Stories 23 03-17-2016 03:09 PM
Full Bolton e85 Boss mustang vs 1993 z28 Mavn Street Racing & Kill Stories 11 01-16-2016 12:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
