Procharged 5gen vs Paxton 5.0 vs C7 N2O - Page 2 - LS1TECH
Street Racing & Kill Stories Basic Technical Questions & Advice
Thread Tools Search this Thread
Old 03-17-2017, 04:04 PM   #21
Quote:
Originally Posted by HioSSilver View Post
Not really. I see no real conclusion that it is.
Now vs the 6gen maybe. But that's only because of lack of di fueling options. Once they start dual injection on the lt's that will go away.
With that said when making power with boost things can go either way in a quick hurry. It far more depends on the set up than the engine type. Examples are even 4cyl can run on boost.
From what I've seen the yote definitely does better when adding fi. The s550' s already come forged in fact. The 6g's run outta fuel around 750 rwhp ish on pump with the lt4 setup. I'm sure gm will answer this fairly soon but from what I see fi wise the yotes has the advantage and responds better than 5 and 6gs on fi.
There is an orange procharged 5g auto here in Houston (I think he's kin to Matt at Florida speed) if I'm not mistaken and that thing is just nasty! It hurts a lot of feelings and is extremely impressive. I'm sure someone on here might chime in who knws more about it than I do.
Fast02Z06 is offline   Reply With Quote
Old 03-17-2017, 07:34 PM   #22
HioSSilver's Avatar
Well i already said it's mostly a fuel issue for the lt's. As for the coyote being forged.....they may have had to go forged to handle the durability of high combustion pressures gointhrough furds development. It is a smaller engine so it's gonna have more pressure in the cylinder than a lt of larger displacement. That would require a better piston. Now how good is the forging is the question. Termi motors had forged pistons but weren't of that great a quality. Cp pistons was a upgrade and thats what's in my termi more.
When you say better at boost i tend to think the engine that makes more power at lower psi and on pump gas is the better one.
HioSSilver is offline   Reply With Quote
Old 03-18-2017, 12:48 AM   #23
snake95's Avatar
Quote:
Originally Posted by MACHXLR8 View Post
5.0 was gone...but that Camaro and Vette lope was killer! Camm'd LS sounds ****.
Stop being nice
LS motors sound like truck motors. A cammed one sounds like a cammed tree fiddy Silverado.
LS7s sound magical with exhaust.
snake95 is offline   Reply With Quote
Old 03-18-2017, 11:38 AM   #24
marc97taws6's Avatar
Extra 100rwhp advantage and seems as though the 5G needed the camera guy in the Br0 to stand a bit more of a chance.
Like others, I too am confused by the th400 swap. 6r80 will handle 680. Maybe it was originally an empty82 car? Only rationale I can think of.
5G and c7 sounded like sex either way. C7 held it's own with meh shifting.
marc97taws6 is online now   Reply With Quote
Old 03-18-2017, 01:03 PM   #25
5.0 can handle more boost reliably then the Camaro, but make power psi for psi... not sure I believe that.
RealQuick is offline   Reply With Quote
Old 03-18-2017, 01:17 PM   #26
islander033's Avatar
Quote:
CFM is what matters, not PSI. Bigger cubes will show less PSI at the same CFM as a smaller cube motor.
Turbos are rated for HP due to CFM performance.
PS.Did you ever get your 7675 on kill? If so what did it run at the 1/4?
islander033 is online now   Reply With Quote
Old 03-18-2017, 07:14 PM   #27
Agreed. Most people think in terms of boost (even though it is a measure of restriction. The LS3 flows so much air that it most likely would register less boost than the coyote given the same cfm coming out of the poweradder. To me this would mean at the same boost level, the LS3 should put out more power (let's say both at 8psi).
I am not an expert on coyotes, but I would not believe the statement made previously about them being better with boost until I have seen a decent amount of examples.
As far as my car, I had meth issues the morning of the dyno and couldn't get it fixed before the first snow/salts here. I suspect I'll hit 800/800 on 93 + meth next time around on stock bottom.
My big issue still remains with the dr's I have on 20" wheels. I don't think there is enough side wall to get them to hook from a second gear roll. Right now I can run 8psi and they still break at the top of second. I think I need more sidewall.
Old 03-18-2017, 07:17 PM   #28
Oh, and nearest track is 1hr 45 min away, so not track times. If would want to trailer it if I do in case something breaks... so I would need to get access to a trailer.
Old 03-18-2017, 07:20 PM   #29
ZYBORG's Avatar
I dont know if I believe that either. I have seen LS3s take 900hp on stock block.
There is just more mustangs doing it, they are everywhere, like cockroaches.
I was out the other day cruising (with my 350lb gf), when out of nowhere was surrounded by 3 5.0s and one Boss.... They started reving their engines at me..... lol.
ZYBORG is offline   Reply With Quote
Old 03-18-2017, 07:25 PM   #30
Same PSI would be greater CFM for the LS3 due to differences in engines.
Lots of fast boosted coyotes out there with no internal mods. LS3 only chance is SBE.
That sux and I bet 800 is attainable.
I can get my shelby to hook on a second gear roll on 19inch DRs. 20s might be a bit harder.
My tracks are 2.5 to 3.0 hours 1 way. Trailer is the best way to go.
Good luck this season man!
Red is red
Old 03-18-2017, 08:01 PM   #31
That_One_Person's Avatar
Coyotes love boost more than I love trashy women. Especially the single turbo ones. He peaced the **** out.
That_One_Person is offline   Reply With Quote
Old 03-18-2017, 08:12 PM   #32
Red is red
i think you posted in another thread, but what tires are you running? Maybe with some break in and hot weather they may start to hook, but who knows.
when I made 703rwhp it was at 5200-5400rpm, far less than my previously peak hp of 6300rpm before I added boost. I think i resolved the restrictions and hope to be able to hold boost and carrier further in the rpm band. I plan to go back in May and see what it does.
thanks for the words!
Old 03-18-2017, 08:16 PM   #33
My DRs are 305/35/19 MT ET streets. I roll around at 18 to 20psi.
Got them for 1/2 price off a C6Z vette buddy that couldn't make them hook for ****. lol
Old 03-18-2017, 08:28 PM   #34
For whatever reason it seems the C6 Vettes of any sort are much harder to make hook than other cars. I've hopped into c6s that are slower at the track and drove them on DRs on the street and they just seem to spin where I dead hook.
Must be that 0 torque life
Old 03-18-2017, 08:42 PM   #35
automach1's Avatar
Well 4v ftw nothing new here. The old lsa cars were and are super lazy without extensive mods.
automach1 is offline   Reply With Quote
Old 03-18-2017, 09:19 PM   #36
BlkMach1's Avatar
I bet that car has an mt82 and the guy got a good deal on a TH400 and went with that instead of the 6r80.
BlkMach1 is offline   Reply With Quote
Old 03-18-2017, 10:05 PM   #37
Nick.H's Avatar
Th400 > 6r80, t56, mt82, 4l80, 4l60, 4l65...
Nick.H is offline   Reply With Quote
Old 03-18-2017, 10:13 PM   #38
Quote:
For a race cah, maybe.
Skreet cah fo lyfe
Old 03-18-2017, 10:47 PM   #39
assasinator's Avatar
Power glide> infinity
assasinator is offline   Reply With Quote
Old 03-18-2017, 10:56 PM   #40
I'm not telling you anything, but bsfc, burn rate, compression ratio, and fuel. The on3 76 I have for tuning and debugging has definite flow limits. I'm curious to see if I can get more out of it than others. It's a throw away anyway. I'm planing to run c16 and just let it eat. I haven't seen anyone push it past 18 psi, or if it can even handle it.
Related Topics
Thread Thread Starter Forum Replies Last Post
5.0 Mustang vs Lexus ISF - Roll Races deanh8 Multimedia Exchange 0 12-05-2016 08:04 PM
The real deal, LS3 vs COYOTE ZYBORG Street Racing & Kill Stories 287 07-18-2016 11:28 AM
408 ss Vs TT 5.0 SOMBeast Multimedia Exchange 10 05-31-2016 02:58 PM
305 vs 302 big hammer Street Racing & Kill Stories 155 05-21-2016 06:15 PM
2014 Gtr vs 5.0 and 03 cobra bullish Street Racing & Kill Stories 29 10-05-2013 07:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
