burning out in manual
ls1camaro.net
Manual: Put the shifter into 1st gear. (Some people do 2nd, see what works best for you). Push the clutch in and rev it up to about 4k RPMs, then quickly remove your foot from the clutch pedal and move it over to the brake pedal. The idea is to use as little braking force as necessary to prevent the car from rolling forward. When you want to make your getaway, simply slowly release the brake pedal and you should start moving forward and leave some nice tire marks in the process!
anyone do the ole' 2 petal with one foot??? run the clutch and the brake with left foot and gas w/ right? i know it can be done in s10s but never tried in anything else..
when i went to the track all i needed to do was rev it to about 2 grand drop the clutch and feather the brake a little bit of course i was running BFGoodrich g-force KDWS's not exactly the pinnacle of sticky tires the first time i tried burning out i revved it to about 2 grand dropped the clutch floored and it instantly red-lined bouncing off the limiter
!LS1 11 Second Club
