'05/06 Gto A4 Vs M6 Ls1 Camaro/trans Am??
If both cars are well driven which car is faster between the LS2 GTO A4 and the M6 LS1 Camaro/Trans AM?? My guess is on top end the power difference would give the advantage to the GTO but from a stop the F-Bod has the upper hand.
Originally Posted by ProjectDuStU
With a good launch the TA should be able to stay infront of the GTO till probably somewhere in 3rd gear, top end the GTO will have a lil more pull, but there is the weight issuse as the GTO weighs considerbly more then the TA stock for stock it would be a good run 1/8 mile TA 1/4 Gto
I would smoke stock LS2 GTOs when i ONLY had a lid and catback. IMHO they don't stand a chance against an excellent running, well driven M6 01-02 F-body. I would pull through the entire rpm range. Its weird but the '04s always did better against me.
