Springs
Springs
If i get some eibach springs 1.3" front 1.6" rear...do i need to do any modifications if my car is stock? i just have a lm1 no headers yet...
LS1Tech Premium Sponsor
Hello, your going to need an adjustable panhard bar, and you will possibly need a set of lca relocation brackets. Depending on what type of driving that you do will decide on if you need the brackets or not. We offer both of these parts and any other suspension pieces that you might need for your car. I will post you a link to our site. If you have any questions please give me a call.
http://www.bmrfabrication.com/
Technically you don't need shocks, but if you want your suspension to work correctly then you need them. Shocks are a weak point in this car even with stock springs, and if you ask me should be addressed for all performance applications. This should be #1 on your list.
The rear end has side movement throughout the suspension travel based upon the the way the PHB connects to it. Getting an adjustable one you can correct the way it sits at the new ride height.
For drag racing, fixing wheelhop, or just getting better launches then LCA's would be up near the top of his priority list.
If he's just daily driving or wants good handling, LCA's are definitely not needed. That downward angle from axle to chassis doesn't really hurt anything for daily driving. Also, the way the axle moves under turns with the LCA's at that angle provides a bit of high speed turning stability. Also I believe the way weight is transferred during braking has benefits with the LCA's at this angle.
just thought I would point out that lowering the car w/o relocation brackets creates an UPWARD angle...
You will need to replace the shocks as well (you can get by with stockers but you won't like the ride, as stockers are not valved for lowering springs). You need an adjustable panhard rod to recenter the rear end underneath the car.
Additional parts are up to you if you want them or not. you dont need LCA's, but the relocation brackets will set your suspension geometry back to how it should be (LCA's parellel to ground)
Just making sure you are agreeing that you don't need them for autox, and probably don't want them.
I still think shocks are #1 though and you can't ignore that.
To clarify that statement, I would get what is necessary to do the job correctly the first time. That is why I would go ahead and replace the shocks as well. Depending on what type of driving you do, AGX adjustables should be fine. Along this the springs/shocks, I would get the essentials for recorrecting the suspension geometry that will be thrown off after lowering. The adjustable panhard rod and LCArelocation brackets will take care of it. lower control arms themselves are not needed atm.
LS1TECH Sponsor
*needing* them, as in everyone NEEDS them just because they lower the car is a myth.
I'm not, and did not, say that they didn't have a function or do anything. They do, and when a car has traction issues and/or wheelhop problems they are quite useful. That doesn't make them a requirement and many cars do not have them that are lowered--including mine. And from a rear end stability standpoint not having them actually helps.
Classis situation of different parts for different needs.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
