car doesn't want to stop at high speeds
Old 11-03-2008, 12:14 PM
1996z28's Avatar
Default car doesn't want to stop at high speeds
For the past year or so the car has not stopped very well on high speeds. Like at drag strips and stuff-- 110 and up mph. You have to stand on the brakes real hard and it does not seem to want to do anything. Finally the brake pedal kind of pops down and then starts to brake better. Has anybody every heard of this? I have put WS6 store drilled and slotted rotors, Hawk pads and completely flushed the brake fluid with dot 4. Please let me know.
Old 11-03-2008, 01:11 PM
LS1TECH Sponsor
Sam Strano's Avatar
Something is sticking if you get a pop and then is stops better. You need to go through the hardware and slides. Something is mechanically wrong.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Old 11-03-2008, 02:00 PM
99345hp's Avatar
^^^ +1. You need to go through the brakes and check everything good. Calipers sticking, slides frozen, etc...
Old 11-03-2008, 02:30 PM
1996z28's Avatar
The front calipers, brackets and slide pins are all new in the front. When I did the brakes in the rear I greased the rear slide pins which seemed to move freely. I guess I will check the rear calipers. Let me know if you guys have any more ideas.
Old 11-03-2008, 07:53 PM
FiredUpZ28's Avatar
Why and why?
Well, sounds like rather a slide pin or a caliper piston is getting stuck. Get it checked out immediately.
Quick Reply: car doesn't want to stop at high speeds
