Rear end not tracking straight
I just noticed that my right rear tire sits a little over 1/2" further back than the left rear tire ( measured front tire to back tire). I have UMI bolt in LCA Relo brackets, UMI non adjustable LCA's, Edelbrock adjustable panhard rod, and Edelbrock non adjustable torque arm. The rear is centered left to right, but apparently the rear is not tracking straight. Could this have been an oversight on my part or maybe a defective/bent part? I suppose adjustable LCA's would solve this?
Thanks for the help!
The relocation brackets are bolt in and held in place by the shock mount bolt and the original lca mounting hole, how could one install them incorrectly? I don't see how they could move unless one of the brackets were to bend. Maybe one of the brackets were "off" and I never noticed?
LS1Tech Premium Sponsor
Also your frontend alignment could be out, because the front lca have adjustment in them. You might could check the gap in between your wheel well and tire on both sides,in the rear. Although thats not real accurate! Like BMR said, you need to check the installation of the control arm brackets first. Then to make sure its not "doglegging" go get an alignment!
I happened to experience a little of this. But mine was all adjustable BMR front to back. Yeah it was fun.
Front tire to back, there is a little over 1/2" difference between the left and right side. I noticed it when I saw how close the right rear tire was to the fender and was not centered. I will look into this!
