Does Baer still make rear eradispeeds?
Been doing some research, and I can't find the Baer Eradispeed rotors for the rear anywhere. Have they stopped producing them in favor of the Decelarotors?
You mean the 2-piece setup? I haven't seen them. However, it's relatively impossible to find Baer info online. I tried to figure out what rotors I had, and what the part number for a replacement blank, non-drilled rotor to fit my hat. Impossible to find.
Call Baer directly and talk with them. Got the answer in about 5 minutes, as opposed to 5 months of online searching.
Kleeborp the Moderator™
Just from the quick search I did, it looks like they were replaced with the Decelarotors, but those look nearly identical to the once manufactured rear eradispeeds. It looks like the eradispeed term is now used only with their two-piece line...I'm guessing since there never was a rear two-piece option for us, they just now call them decelarotors.
I just got off the phone with Baer. They no longer make the rear eradispeed rotors. The front eradispeed 2 piece rotors are still made, but you will have to go with the 1 piece decelarotors for the rear. They also make the 1 piece decelarotor for the front.
No, but my guess would be because they couldn't justify the extra cost of the eradispeed rears vs. the decelarotors. They are both 1 piece cross drilled and slotted rotors. I guess from a business standpoint it makes sense.
A far as I know Baer never made 2 peice rear rotors for the F-Car, due to the parking brake is in the rotor hat . . .
I have Baer rotors on all four corners of my Camaro, and the front are two peice the rears are one piece. . . .
Not the best pices, but here are the fronts . . .
and the rears:
and the rears:
