Bleeding brakes on an 02 WS6.
I know how to bleed brakes. From the right rear, then the left rear, then front right, then driver's front. But is it still the same if the car has a line lock.? I pulled the motor and had to replace a couple of brake lines. Reinstalled the motor and the new brake lines, bled the brakes, and got good clear fluid out all four corners. But the pedel isn't real firm, my BRAKE light came on and stays on. And I have floated through a few intersections while driving. The car stops but not on a dime, and the pedel will sometimes go to the floor. Thanks
I would bleed it again maybe theres still a bubble in there. Jack the rear of the car up and leave it over night. Let the air move itself to the rear of the car then try it again.
