which shocks for best ride
i want some new shocks and struts for best ride. my stockers have 127,000 miles.. Is monroe sensatrac good for these cars? i dont race. i drive my car everyday and want a good ride.
LS1TECH Sponsor
Hi!!!
Monroe's suck, especially for this car. I generally recommend Bilstein's in this case as they are best combination of ride, price and quality. You can spend a bit less and have a similar but not quite as composed ride with Tokico's (but you also get a shock that's less durable).
And Bilstein's are't all the same.... I do a set that uses a different rear shocks valving (though it's a production part, not anything I reworked) because the standard rear shock is too much like the OEM shock. It's got too much compression damping and not enough rebound control. That's what everyone else who sells Bilstein's sells. I use the same front (which work fine), but with a rear that is more composed, and more like the older Bilstein's before the "new and improved" (quotes for sarcasm) rears showed up.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Pontiacerator
