UMI ADJ LCAs and ADJ PHB
I took advantage of Byunspeeds/UMIs nice sale and ordered these parts finally.
I'm so happy I did. My car feels more stable through sweeping turns, quick turns, etc.....
I can also roll slightly from a stop then mash the gas and hook right up on my stock size street tires. This was last night, the temp was near freezing....
I suggesting buying these parts if you haven't already. Even without the discount I would have been happy
No I can take pictures on the parts on the car. I don't think that will help as much though lol.
It's very straight forward as far as installation goes. Make sure you have a 21mm open end wrench since you can't use a ratchet when taking the bolt off of the passenger side Panhard Bar unless you jack that side up slightly.
It also a good idea to have ramps. I'm no mechanic so anyone can do this. I would also recommend a rubber mallet/hammer.
My rod ends didn't quite fit as they were really snug and required some massaging to get in. Which is good in my eyes that wa I know it is secure in the Lower Relocation Brackets.
If ou have any questions feel free to respond or pm me.
I have a couple of questions:
Did you get the single adjustable units?
Did you get and install the relocation brackets at the same time?
What did you car used to do, spin, hop, or something else?
I already have the PHB and I think it is an excellent quality piece, but I have been putting off on the LCAs.
Did you get the single adjustable units? Yes Single
Did you get and install the relocation brackets at the same time? No Prior
What did you car used to do, spin, hop, or something else? Spin slightly, felt sloppy overall in the rear
Torque Arm NEXT!
Now, go get the UMI Adjustable Torque Arm, with the DS loop, set it to -3.5 degrees and thank me later!
It makes it even better!
Yep
Just think about it; any 12 bolt or 9 inch made for our cars has a place for a stock Torque arm to bolt to it, this adjustable torque arm bolts up using the same connection points, therefore, YES! it will be usable after you upgrade your rear end too!
I have only driven my car for one day since the install but it feels a lot better when taking turns aggressively. The traction was slightly improved but i still spin in 1st. I'm going to try a few more times and see if the traction has improved
(I don't want to sound too much like a jerk, but...)
Hello,
Like mentioned our torque arms will bolt to virtually any rear end... the popular rear ends like the Moser 12-Bolt and 9" as well as the Strange 12-Bolt and S60 are no problem at all. We just don't recommend our non-adj. torque arm on the 9" because it requires some grinding.
Hope that helps!
Ryan
Hope that helps!
Ryan
Hello,
Hope that helps!
Ryan
Hope that helps!
Ryan
I love how involved you guys are on this site.
