suspension issue
suspension issue
i just replaced a thorq arm on a 98 trans am for a friend of mine his broke at the axle housing. before it rode like a wagon and ot cut the bolt heads and flangs for the u joints but not bad but the owner wants to replace it, before putting the car down off the lift i looked around the suspension and didn`t see any other issues. but it still ride like a wagon i feel the spring my have been damaged but unsure i will be putting it on the lift again on thurs. but looking for any ideas of what to look for other than the springs.
Way too vague.
Does he have any other aftermarket suspension? Bushings? Wheels/tires? What are the tire pressures set at?
If all else is is good working order I have my money on shocks.
the suspension is totaly stock with stock wheels and tire size the shocks were replaced about a year ago he said but i see what your are saying if the axle rotated enuff it could have bent the shock tube binding up the movement.thanks i`ll let you know
LS1TECH Sponsor
He didn't hurt the springs, but breaking TA's does often break shocks. It's not good when a shock is connected to the axle and body and when the TA breaks the axle rotates, but the shock can't rotate as far. Things bend like shock shafts.....
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
It happens occassionally...
__________________
