Cheapest place for Wheel Hubs ?
Old 01-07-2009, 02:10 AM
SS DNA's Avatar
Default Cheapest place for Wheel Hubs ?
I need to replace my drivers side and Im wondeing where you guys seen the lowest prices. Summit Racing has some for like 300+ dollars
Local Autozone has them for like 130 I believe.
Old 01-07-2009, 02:21 AM
Nick_Rapitis's Avatar
check some part-out threads, junk yards, and ebay...do you have an federated auto parts near you? they may be cheaper than autozone
Old 01-07-2009, 07:53 AM
mitchntx's Avatar
That's about right ...
Old 01-07-2009, 10:19 AM
SS DNA's Avatar
No I dont. On Thursday I have a day off so Im going to do some searching.
Old 01-07-2009, 05:32 PM
mitchntx's Avatar
Just for reference, other than genuine GM, I seem to have the best result from National brand.
I replace mine every year during the off season.
Old 01-07-2009, 07:31 PM
SIK02SS's Avatar
i dunno how viable it is for you, but on frrax a member designed a new rebuildable front hub..
Old 01-07-2009, 08:30 PM
shaun's Avatar
its risky going with a junk yard hub because you dont know the condidion of it untill you do all the work and it also could be worn.
i got my passenger side wheel hub from advance auto for around a 100.
the swap is not that hard but you will have to rent an axle puller to get the hub off of the spindle.
i had to borrow one from the parts store to get the hub off because of rust ans i just used some of my wheel lugs to mount the claw to the hub then just started pullin lol it only took about 3-4 pulls but there was no way of geting it off with out the puller i tryed every thing.
Old 01-07-2009, 11:24 PM
99Bluz28's Avatar
Get some timken hubs!
Timken #513090 around $135-140 ea. online
PM sent.
Old 01-08-2009, 08:10 AM
Major_Lee_Slow's Avatar
Timken buys these Hubs from Delphi and Delphi supplies the OEM hubs. With that said, I went thru six pairs of Timkin Hubs this last summer. However I do autocross the car, and I run 315's on all four corners, plus I probably don't put enough road miles on them prior to autocrossing them. One theory is that the more road miles are on a set of hubs prior to running them hard, the longer they will last. It gives them a chance to break in.
Autozone sells Timkens and they offer a 1 year warranty.
Old 01-08-2009, 05:01 PM
SIK02SS's Avatar
how many road miles do they say it needs so it helps them to last longer?
when running stock size tires (like a NT-01 or R888) how long do the hubs normally last from canyon/track days?
Old 01-08-2009, 05:54 PM
That is still undecided. The last two sets I put 40 miles on them before autcrossing. One set I did a straight 40, the second set I did 20, let the car sit for a few days, and then 20 more miles. I was able to get 12 runs out of these hubs before they were "loose" vs. only 6 runs when I didn't put miles on them. My stock hubs lasted for 9 years, and I put 10,000 miles on them before the first autocross.
Old 01-08-2009, 07:17 PM
SS DNA's Avatar
Yeah I was just going to buy some Timken from Autozone. I just wanted to see what else was out there. I bought them before for other cars and they are GOOD.
Old 01-08-2009, 09:46 PM
mitchntx's Avatar
With 275 RA1s, I went a whole season on the Nationals I got from O-Reilly's with 1/2" wheels spacers.
Old 01-09-2009, 01:03 PM
SIK02SS's Avatar
hmm...i should probably check mine then
