stranos with kyb agx shocks?
i ordered my stranos today and was thinking of just putting them on my car with the stock shocks ( car runs smooth anyways) but i was thinking i will eventually end up buying shocks and might as well do it all at once... i know koni are the best shocks but they are realllyyy expensive and i was looking at the kyb agx shock set?... anyone running this with stranos?.. can you tell me if you like it or hate it.. thanks
Liking KYB shocks with strano springs...
https://ls1tech.com/forums/suspensio...between-9.html
Take it easy
Brewski
Take it easy
Brewski
I have a set that I'll be putting on when my Strano springs get here. From what I've gathered here is that they are one of the best choices next to Koni's. Definitely check out the link Brewski posted, there is some great info in there!
the shocks are the most important piece of your suspension.
people say they are the best, and after installing them on my car i can agree. in short what i can tell you is that my car does exactly what i make it do. and i have 0 body roll, all the while it still rides smooth as butter.
LS1TECH Sponsor
What are you guys wanting to know??? This has been talked about, more than once.
AGX's don't magically become Koni's on my springs. I sell AGX's because that's all some folks can swing and having the ability to adjust the shock gives them some tuning options, and the shocks can control the spring rate. That said, I don't and won't use AGX's on my own car. The Koni's offer more composed damping control without as brittle a ride... and are built a lot better... and are backed by a much better warranty.
If it's all about money and you can't do Koni's, then AGX's are an option to strongly look at. If you can afford Koni's and you are wavering about the price, you need to decide how good you want the result to be. You get what you pay for here fella's.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
Shocks don't make the car roll less... if you run more rebound damping they slow the rate of the roll, but not the amount of it.
Stock shocks are pretty harsh espeically with miles on them. So given your criteria, I think you'd probably find AGX's to be good enough. Koni's are just better at everything in terms of how they work.
__________________
