Upper a-arms questions
Old 01-10-2009, 08:07 PM
Dabeztz28's Avatar
Default Upper a-arms questions
Hello,
Are the upper a-arms that same for lt1 cars and ls1 cars?
thank
ivan
Old 01-10-2009, 09:02 PM
UMI Performance's Avatar
Yes they are the same on all 93-02 models.
Hope that helps,
Ryan
Old 01-10-2009, 10:22 PM
SmokedOutZ28's Avatar
Hope that helps,
Ryan
Do your adjustable uppers and lowers come set already?
Also do they come loaded with ball joints as well?
Old 01-10-2009, 11:38 PM
robsquikz28's Avatar
no they dont
Old 01-11-2009, 12:54 AM
Greekey's Avatar
Umi's lower A-arms already come with set with Moog problem solver ball joints. Their upper a-arms do not come with ball joints. But putting in upper ball joints is a matter of bolting three bolts to the a-arm. I got their lowers a week ago and im just waiting for the uppers right now, with a few other things
Old 01-11-2009, 01:41 AM
Yeah uppers are easy I was just wondering if they came with like the lowers.
Old 01-11-2009, 06:47 AM
Hello,
YES our upper and lower A-Arms are pre-set to factory length during assembly... usually with in a 1/16th of an inch.. you may still need to make a few small adjustments but we give you a good starting point.
The lowers come fully assembled with new ball joints installed. The uppers do not come with ball joints... but when you purchase the upper ball joints new they just bolt on to our arms, not pressing.
Let me know if I can help anymore. Thank you!
Ryan
Old 01-11-2009, 02:27 PM
some_punk's Avatar
for the upper a-arms are the grease fittings supposed to be facing down or up?
Old 01-11-2009, 02:55 PM
ScrapSilicon's Avatar
for the front upper a-arms ...up
Old 01-11-2009, 02:56 PM
Greekey's Avatar
+1
Old 01-11-2009, 06:45 PM
some_punk's Avatar
From the pictures from umi's website it looks like it is facing down.
Old 01-11-2009, 09:29 PM
your original post in this thread didn't specify stock or otherwise ..on stock there is usually only the ball joint that gets lubed(a zerk fitting on the upper ball joint would face up as the threaded/ball portion faces down thru the spindle) not the stock bushings..
Old 01-12-2009, 12:10 AM
some_punk's Avatar
I was talking about the grease fittings for the poly bushings.
Old 01-12-2009, 08:26 AM
UMI Sales's Avatar
Hello,
On the non-adjustable upper A arms the grease fittings will face down towards the ground.
If you have any additional questions please ask and I will be glad to help. thanks!
Brad Conrad
