NEED ADVISE on Suspension?
I purchased some front Koni S/A shocks and ground control kit with 550 lbs springs a few months ago I only wanted the shocks but the person I bought the kit from would not sell it seperately. So I whant to know if the set up is to extreme for a DD bird that sees the track once in a while? I have only had experience with the pro kit which I don't care much for either.
LS1TECH Sponsor
Same rate, but that's not the whole deal, it doesn't take into account the ride height and working travel vs. the rate. And as much as I hate to say it, you find the majority of broken Koni's on cars that have adjustable coil-overs from folks running them too low and that can break the shock.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
You lost me madmo
Pro-kits aren't the best springs out there, far from it. While the rate is 'pretty mild', that's part of problem. They aren't actually firm enough to properly counter the amount of drop we get.
Further, Koni themselves does not make springs for this car, just shocks so I'm not sure how you can draw a comparison. What exactly are the "same rate"?
__________________
There's a big difference in the spring rate up front!
LT1 Pro-kit 377-600 lbs./in.
LS1 Pro-kit 400 lbs./in.
Also what amount of drop are you wanting?
Mild <1".
Normal 1.2" to 1.4".
Slam > 1.6".
First of all guys thanks for your input, I have only had the LS1 prokit on a 98 SS that rode pretty rough but with the help of some revalved blisteins from Strano that really made a diffence. As far the drop height I felt the pro kit was fine.
So what do u guys think, I dont want to pay for installation only to be dissapointed by these springs. I got stock spring in the back with the hose mod and Koni's and that is perfect for the rear in my opinion.
