Springs
From searching it appears they claim a 1.5" drop (a bit too much), and don't list their spring rates which means that should be an automatic pass. Buying springs without knowing their spring rates is like buying a cam without knowing its lift/duration.
You can search and decide yourself what the majority rules to be the "best" lowering spring. But if you are looking to improve handling you should not even be considering springs until you get some good shocks on the car.
