Adjustable lca's ?
Old 01-17-2009, 06:43 PM
97_GEN3_SS's Avatar
Default Adjustable lca's ?
I have bmr adjustable lca's and relocation brackets but i dont understand how to set them to get the best launch and eleminate wheel hop. If someone could help i would appreciate it thanks.
Old 01-17-2009, 08:03 PM
twitchtwice's Avatar
the more level the lca is the least amount of wheelhop you will have is what i understand.
Old 01-20-2009, 09:37 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Hello, after you get the relocation brackets installed the lower that you put the rear of the control arm the more you move the instant center of the car rearward. The holes in our brackets are drilled on an arc so you will not have to adjust the length of the lca's if you change the hole that you are using. Unless you are using a very tall tire the lca's can be the same length as your stock arms. Just make sure that you have both sides the same length. If you have any questions please give me a call.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 01-20-2009, 12:44 PM
97_GEN3_SS's Avatar
Thanks for the help now it makes sense.
Old 01-20-2009, 03:51 PM
BMR Tech2's Avatar
If you ever have any questions please give me a call.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
