Getting My Ride To Hook!!!!!
It seems I'm having a little trouble hooking. I have a 2001 Camaro SS M6 w/ BMR adj. lca's, BMR adj. torque arm, BMR adj. panhard bar, and a set of 18x10.5 BFG TA KDW's out back mounted on a 10 bolt with 4.10's in it. Other than that my suspension is pretty much stock. I have a set of Strange Drag Shocks for all four corners and BMR lca relocation brackets, but haven't made it on my ride yet. I have the front sway bar still hooked up, everytime I try to launch it I can feel the rearend wanting to bite the pavement but it feels like the front end does not want to let it travel. Any feedback on what might be wrong would be deeply appreciated.
If you don't care about your cornering performance, remove the front sway bar. That will allow to the front end to rise. I do hope you don't have a stock 10 bolt, because and soon as you do finally hook up, you are going to scatter that bad boy.
I noticed you have a lot of you suspension done, but I would also recommend Sub frame Connectors to stiffen up the chassis. And they would also allow the car to distribute weight through out the car more evenly!
Thanks Again!
Brad
LS1Tech Premium Sponsor
sounds like you have all the correct parts... get the relocators and most importantly the shocks on the car. the biggest problem you have is the tires. the 18 inch bfg's aren't going anywhere now and never will. only thing you need to purchase is a set of good tires like M/T drag radials or ET Street's.
