View Poll Results: Wich shocks
Strange 10 Ways
7
15.91%
KYB AGX
11
25.00%
Bilstien
18
40.91%
QA1
8
18.18%
Voters: 44. You may not vote on this poll
Shocks
Old 01-25-2009, 07:02 PM
95_transam_lt1's Avatar
Default Shocks
What shocks should I get? I would like to stay american made like Strange and i like that they are 10 way adjustable. But it is a cruiser so I am looking for opinions. KYB AGX, Bilstien, Strange, or QA1
Old 01-25-2009, 07:17 PM
tillery's Avatar
Call a few suspension sponser on here and ask them about the QA1s and Strange, They will tell you that the QA1 is metric and not all that american, and the Strange is a better choice of the Two. I have QA1s and am switching mainly cuz they need to be rebuilt. And it has been a pain to get parts.
Old 01-25-2009, 07:18 PM
what are you switchin to?
Old 01-25-2009, 07:20 PM
tillery's Avatar
Konis.
Old 01-25-2009, 07:22 PM
Choppers's Avatar
Konis
Old 01-25-2009, 07:48 PM
JD_AMG's Avatar
You want to stay American made but you list Bilstien which is German, and KYB is Japanese.
(and you are driving a Candian made car, with parts from all over the world )
Your description is very brief, what exactly do you want to change about the car by getting shocks? Control? Handling? Feel? Weight transfer? Ride quality? The list of shocks you have are from opposite ends of the spectrum, two being drag shocks and the other two being handling shocks.
Old 01-25-2009, 08:15 PM
Its a cruiser. I was talking to people and they said i can adjust the strange shocks to be more for handling. By staying american i meant i would like to use the american one (strange) but want the best thing. I do not have the money for konis at the moment. I want it to handle better but i also do alot of "racing" more just messing around with people at stop light while im cruising. I am changing shocks because im doing Strano springs. and i have a harder side wall tire that will cause more road deflection. So i want to compensate for that. Bassically I want it to ride as good or better and handle as good or better at the same time without making it ride like a truck.
Old 01-25-2009, 09:01 PM
JD_AMG's Avatar
Since you're buying Sam's springs why don't you give him a call and see what he suggests you run? (also should have mentioned you are buying lowering springs, which cancels out the bilstiens, which are designed for stock spring rates at stock height)
All I can tell you from experience is if you want good ride quality and good handling stay away from drag shocks (like QA1 and Strange).
And FYI both QA1's and Strange are about as much as Konis are.
INMY01TA's Avatar
Strange and QA1 are drag shocks, you won't like for cruising. I vote Bilstiens.
Old 01-25-2009, 10:07 PM
I will give sam a call and see what he can do for me. thanks JD
Old 01-26-2009, 09:54 PM
any other words of wisdom?
Old 01-26-2009, 10:19 PM
BlueBird346's Avatar
Strano told me that drag shocks dont ride good at all.
Old 01-27-2009, 07:44 AM
mad_steve's Avatar
Strange double adjustable would be your best option for a street-rod. I personally would get AFCO's, but they are more expensive and suited for drag racing. Strange makes a good DA shock, and are very reliable. We're a dealer for Strange, so if you'd like to order a set of shocks, give me a call. 225-673-3533
Old 01-27-2009, 12:05 PM
LS1TECH Sponsor
Sam Strano's Avatar
Very generally that's true. The valving you want for drag racing is very far removed from the valving you want to control a car that is street driven, let alone driven hard or with more handling based components (like lowering springs).
What many don't know, and what I like to point out is this: Koni has for years made drag shocks. That's not what I use on this car, and it should be noted that Koni's drag shocks include a note that states the shocks are not intended for highway use...doing so may result in personal injury. That's because the valving is not about giving the car control, it's about getting it to leave.
Now if Koni, one of the most world-renown damper companies in the world can't make a shock that "does both well", considering the range of dampers they do make (including those on McLaren F1 cars), I don't believe you'll get a very good drag/control shock elsewhere. I use the Koni Sports, and while not intended to drag we have a number of folks on them in dual purpose cars with not exactly crappy 60's.
I realize I digressed.... sorry. I just got on a thought and had to follow it through.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Old 01-27-2009, 05:09 PM
jmilz28's Avatar
You're getting Sam's springs, call him and get the shocks he recommends. It will be his revalved Bilsteins or Konis. Listen to him, you will not be sorry. My vote is Konis, wish I had.
Old 02-03-2009, 02:02 PM
zlicious94's Avatar
So how much to revalve a set of slp bilsteins?
Old 02-04-2009, 02:01 AM
99Bluz28's Avatar
Lightbulb
Get a set of Koni DAs, that's your best bet. If you have $1500 to spend on shocks.
Old 02-04-2009, 03:18 AM
nemss1's Avatar
get koni DA's. love mine and ride great
Old 02-04-2009, 10:46 AM
LS1TECH Sponsor
Sam Strano's Avatar
I have to disagree with both of the above statements. Why? Well, because I own a set of DA's---yet that's not what I run on my car.
In fact, only one of my National Champioships was won on DA's (and even then I was running the compression full soft).
I don't see the reason to spend more on a more fragile shock (more to break and less compression travel because the bump adjuster is stacked onthe bottom of the shock).
__________________
Old 02-04-2009, 10:59 AM
99Bluz28's Avatar
Question
With the Koni DAs he could set the compress, and rebound for drag racing, then when he leaves the track re-adjust them for street/corner carving, correct?
Sam,
Wouldn't the Koni DAs be a better option, then DA drag shocks for a dual purpose shock?
