New to suspension. What would you recommend?
I've searched around but found nothing, so here I am asking you guys. I want to lower my car about 1.5" to 2". I've seen a lot of people getting Eibach lowering springs, but then I've heard other people say that my car will ride horribly. What are good shocks and springs that arn't too expensive? Keep in mind I am mainly doing this for the look.
Also how hard would it be to install it myself? What major tools would I need?
Hello
Hello,
Spring wise......I would recommend the Eibach PRO kit you will be able to get your 1.5 drop and they also have kit called the sportline that is a little more aggressive lowering set up and you would have to go with a adjustable panhard bar due to lowering your can more than a 1.5 you would have to recenter the rear end back up. If you have any other questions feel free to ask!
Thanks Again,
Brad
Thanks Again,
Brad
Hello,
Thanks Again,
Brad
Thanks Again,
Brad
The rears are too soft and on the bumpstops all the time. If you ignore this advise at least get the LT1 prokit as they have a little more rate on the rear. Just about anything else is better with Strano, Hotchkiss. BMR, Voightland, LG (really low though), DMS (if they are still in business) and a couple others out there. Ground Control kits are nice too but pricey and kind of a PIA.
Search this really well and make an informed decision so you won't be dissatisfied. I had a friend who bought his car with sportlines on it about 3 years ago and within a month hated it and was on DMS springs. Before I bought my car I test drove two more and just hated the bounce and the jarring ride of the bumpstops.
You'll really need to search shocks while your at it. The springs will kill them if they are not already toast. Mine were trash when they came off at 62K for the Konis
no offense umi but eibach sucks for these cars
The rears are too soft and on the bumpstops all the time. If you ignore this advise at least get the lt1 prokit as they have a little more rate on the rear. Just about anything else is better with strano, hotchkiss. Bmr, voightland, lg (really low though), dms (if they are still in business) and a couple others out there. Ground control kits are nice too but pricey and kind of a pia.
Search this really well and make an informed decision so you won't be dissatisfied. I had a friend who bought his car with sportlines on it about 3 years ago and within a month hated it and was on dms springs. Before i bought my car i test drove two more and just hated the bounce and the jarring ride of the bumpstops.
You'll really need to search shocks while your at it. The springs will kill them if they are not already toast. Mine were trash when they came off at 62k for the konis
LS1TECH Sponsor
The lower you go, the worse the ride... You have less travel. So pick your poison, looks or a better working result.
Eibach Pro-kits aren't great for these cars, Sportlines are worse. Eibach is not alone there are a lot of not so hot springs out there.
You need to prioritized your wants, in order to begin to get a setup that suits your needs. Until you do that you are only gathering random opinions.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Best looking stance?
Lots of folks say the Eibach Sportlines. you'll hear lots of folks say that the ride quality BLOWS, and you'll hear a few folks say that their ride quality is GREAT...but hey, you want it to look good, those are for you.
LT1 Prokits will work fine, about .5-1" taller than the Sportlines.
HRR, Hotchkis, DGM(if they're still in business), Strano, all within .50" of each other I would imagine.
LGMotorsports springs give you a bigger drop, close to the Sportlines, but they're a lot stiffer than the Sportlines.
There you go.
Know this, you may end up justifying that your ride handling/quality is better, compared to what you have now, you would probably be right, but that's not saying much. A set of stiff shocks will drastically help with your ride quality...and NO, replacing your factory shocks with another set of DeCarbons or Monroes Sensatracks will only help temporarily, you will soon BLOW those shocks with the above springs as most of them are significantly stiffer than the factory springs AND they sit lower. Buying fair OEM replacements as opposed to higher priced shocks (i.e. Koni's) you ride quality will be better for about 10K-20K miles, and your shocks will be slowly breaking down internally, you probably won't even notice till a couple of quarters later you'll say something like:
**** my back hurts!!!
My .02
Good luck!
There you go.
My .02
Good luck!
LS1Tech Premium Sponsor
http://www.bmrfabrication.com/F4.htm
LS1TECH Sponsor
I have to say that I don't think Tokico's are the best choice in particular. I don't say that to slight Dennis, I sell them as well. Bilstein's aren't a lot more money, but a lot better quality.
That said, I don't feel that either are great for lowering springs of the rates up and around Strano and BMR type springs, which includes a lot of them. Tokico's and to a lesser extent the Bilstein's are best suited to stock, or lower rate lowering springs (which themselves are a compromise).
__________________
