spohn solid motor mounts
Old 02-06-2009, 08:48 PM
coolz28's Avatar
Default spohn solid motor mounts
has anyone had any problems with spohn solid motor mounts? i just installed mine and the engine does not set level. it sets 2 degrees to the pass. side and is very noticeable by eye. anyone with issues?
Old 02-07-2009, 01:10 PM
loreak's Avatar
interesting, i was planning on getting them so im interested if anyone else had this problem as well.
Old 02-07-2009, 02:26 PM
Lt1Porsche's Avatar
The motor is mounted in the engine bay that way naturally. It just appears more noticable because the mounts are solid.
Old 02-07-2009, 05:17 PM
coolz28's Avatar
i have a stock mounted ls f body right beside mine and it is fine. since it is not level, it is throwing my trans mount way off as well.
Old 02-07-2009, 06:28 PM
Grifter's Avatar
I didn't notice any problems with mine. I think it lifted the driverside up slightly but nothing drastic. Would a picture be able to show the lean?
https://ls1tech.com/forums/generatio...or-mounts.html
Old 02-07-2009, 07:20 PM
coolz28's Avatar
yes it will. i will try to post some pics later tonight.
Old 02-07-2009, 08:07 PM
shoemike's Avatar
2* would not be noticeable, if it is off its off more than 2*.
IIRC the mounts are side specific.
Maybe you have them reversed.
Old 02-07-2009, 09:38 PM
coolz28's Avatar
2* is what my angle finder reads and it is way to high on the drivers side. the mounts are marked l or r and only go on one side-they cant be reversed.
Old 02-07-2009, 10:17 PM
Lt1Porsche's Avatar
Well no one else has a problem like yours so it is either due to a bad part (unlikely) or installation errors. Something isnt right if noticing a problem that bad. I used the same exact mounts. Everything lines up perfectly and trans mount lines up perfectly as well. Motor sits a bit to the passenger side but thats normal.
Old 02-07-2009, 10:48 PM
coolz28's Avatar
thanks for the help! i am going to talk to spohn on monday to see what the deal is. ive used lots of their stuff before with no problems. i like spohns products, maybe its an issue with the k frame. the k frame is from pa racing. (moly frame)
Old 02-27-2009, 02:39 PM
metalmechanic's Avatar
i have them and no issues
Old 03-16-2009, 09:02 PM
CanuckSS's Avatar
My motor sits on an angle as well. I am in the middle of trying to remedy the problem. I built another motor mount for the d side to level the motor out but now the steering shaft is hitting the header. The collector on the d side header was also almost touching the floor using the spohn mount. I am guessing I am going to have to live with the situation.
Old 03-16-2009, 09:49 PM
Randy WS6's Avatar
I have the Sphon solid mounts and my motor set level from what i can tell,If the mounts are not right, they wont bolt up. The angle on the mounting plates hast to be right or the mounting plate on the other motor mount wont line up. Do you have any pics of your motor?
Quick Reply: spohn solid motor mounts
