Wheel Bearing??
Old 02-09-2009, 06:48 PM
BradsLS1's Avatar
Default Wheel Bearing??
So I want your guy's opinion before I go and throw a new wheel bearings on my 99TA. I have this slight rubbing noise and vibration coming from the front of my car at about 60 to 70MPH. It goes away when I make left turns on the highway any speed below 60 I don't hear it anymore. I jacked my car up and shook the tire on both sides and they seem fine. Do you guys think its a wheel bearing or a alignment issue. My tires seem fine as wear goes but I don't drive it to much to really notice at this point. Thanks guys.
Old 02-10-2009, 09:17 PM
Major_Lee_Slow's Avatar
If it was an issue with the wheel bearing you will be able to rock the wheel assembly in and out by pulling on the 12:00 position and pushing on the 6:00 position. It will be really obvious that there is an issue because you will totally feel the wheel rock in and out. I should know, I went been thru more hubs last season than most people do in a lifetime.
Quick Reply: Wheel Bearing??
