Car has been handling weird
Hey guys,
A few months ago I had sold my QA1's due to a problem, and bought KYB AGX adjustables and Eibach pro Kit spinrgs. Since then, a month ago or so I had made my front shocks tighter because I had been having some play in the front end.
The front would make some clunking noises upon hitting the brakes hard or pulling into my driveway. Also if I were to cut the wheel all the way, as if I were turning around, the car would "skip" across the ground rather than roll slowly like I would expect it should. From those few months of the KYB's breaking in, the steering wheel became more loose as well. It used to be really stiff and very responsive, now it's more loose. Since I have tightened the shocks up, it's occurring again. Are the shocks being worn by the springs? Is this normal or what? I'm afraid something's going to break or somethin' lol.
Thank you everyone
Thank you everyone
to check your ball joints raise the car up and put jackstands under the lower control arms and let the car down so all the weight is on the jackstand.get a long prybar and a buddy and have your buddy put the prybar under the tire and lift up on it.while hes doing that watch the ball joint for movement,there should be no up and down movement in the ball joints at all.
Or just see if the boots are ripped or damaged. GM put sealed joints in with no grease zerks for regular maintance. Oh, and if you take everything apart they should be pretty tough to move around by hand. If they are easy or anything like that, they are worn and probably should be replaced.
