Use loctite on rear lCA bolts ?
I've replace my lca bushings with the harder 1LE ones and installed them without loctite (late at night and didn't think about using any)
Should I have any concern, or is it ok to skip the loctite?
(would have used it had I remembered)
As long as you tighten the bolts correctly, you should be fine. IIRC they should be torqued to 100 lb ft. Every suspension fastener I can remember was dry from the factory.
If you caught my post last week, MINE FELL OUT LOL....LCA was dragging the ground, Freaked me out. Ran to autozone and ended up holding it up with a wire untill later that night running to my buddies so we could fix it. Crazy, Autozone guy said...Ill be Damned, your Damn stabilizer bar is dragging the ground.
