So I installed 1le rear lca bushings . . .
Bought them on ebay and hammered them in (found a guide online for diy)
Installation was simple with rhino ramps.
Felt that it tightened up the rear and helps put power down a little better out the hole and corners. Ride felt the same, no extra harshness.
Cheap and easy mod!
Cheap and easy mod!
Cheap and easy mod!
Cheap and easy mod!
LS1TECH Sponsor
The price as changed some, but a full set is 4 bushings (2 for each arm). Current pricing is $57 for the complete set.
These are in a Moog box, but the are the very same (complete with the same casting numbers) as original 1LE bushings, and readily available.
Link to them on my website: http://www.stranoparts.com/partdetai...D=18&ModelID=7
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
