View Poll Results: Koni vs QA1 which do you prefer over the other and why?
Koni
26
72.22%
QA1
7
19.44%
Other
3
8.33%
Voters: 36. You may not vote on this poll
QA1 vs. Koni
I have Koni DAs in my 3900# fbody and new stock springs
2 weeks ago went 1.44-45 60' I had the front rebound full soft and compression 3/4 stiff...front end rises and stays up...coming down slowly.
Rear had the compression 1/3 from full soft to keep the rear from hitting the tires too hard and bouncing off the rim....rebound was full soft. QA1s didnt have enuff dampening for my car to work like they should and the Konis work better for MY car.
LS1TECH Sponsor
Wow, good to hear cablebandit. I'm not 100% shocked (ok, bad pun... let's say surprised) as I've had lots of reports of folks in the 1.5-1.6 range with Koni's on my lowering springs.
Good to have a new "best", and a comparison from someone who's had both.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
